this is a zwave battery-operated motion sensor designed similar to those on motion-sensing lights. It is marketed as a wink device. I got it to work as a generic z-wave motion sensor but noticed it was triggering events with the current temperature. It also originally "auto-detected as a smartsense multisensor with the only functional reading the temp. I took code from that and plugged it into the z-wave motion sensor groovy code and got it to work! You can now use it to alert off of temperature as well as motion. Example: You have pin switches telling you when your windows are open. You can detect if it’s hotter outside than inside and send you an alert to shut them.
i just joined github and have not figured out how to upload code yet so i’m putting it here. I hope it helps someone.
* Generic Z-Wave Motion Sensor
* Author: SmartThings with modifications by John Lord
* Date: 2013-11-25, 6-10-2015
metadata {
// Automatically generated. Make future change here.
definition (name: "Z-Wave Motion Sensor", namespace: "smartthings", author: "SmartThings") {
capability "Motion Sensor"
capability "Sensor"
capability "Battery"
capability "Temperature Measurement"
simulator {
status "inactive": "command: 3003, payload: 00"
status "active": "command: 3003, payload: FF"
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state("active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0")
state("inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state("battery", label:'${currentValue}% battery', unit:"")
valueTile("temperature", "device.temperature") {
state("temperature", label:'${currentValue}°', unit:"F",
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
main "motion"
details(["motion", "battery", "temperature"])
def result = null
if (description.startsWith("Err")) {
result = createEvent(descriptionText:description)
} else {
def cmd = zwave.parse(description, [0x20: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
if (cmd) {
result = zwaveEvent(cmd)
} else {
result = createEvent(value: description, descriptionText: description, isStateChange: false)
return result
def sensorValueEvent(Short value) {
if (value) {
createEvent(name: "motion", value: "active", descriptionText: "$device.displayName detected motion")
} else {
createEvent(name: "motion", value: "inactive", descriptionText: "$device.displayName motion has stopped")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd)
def result = []
if (cmd.notificationType == 0x07) {
if (cmd.event == 0x01 || cmd.event == 0x02) {
result << sensorValueEvent(1)
} else if (cmd.event == 0x03) {
result << createEvent(descriptionText: "$device.displayName covering was removed", isStateChange: true)
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId))
if(!state.MSR) result << response(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
} else if (cmd.event == 0x07) {
} else if (cmd.notificationType) {
def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, displayed: false)
result
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
if (!state.lastbat || (new Date().time) - state.lastbat > 53*60*60*1000) {
result << response(zwave.batteryV1.batteryGet())
result << response("delay 1200")
result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = new Date().time
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
def map = [ displayed: true, value: cmd.scaledSensorValue.toString() ]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
map.unit = cmd.scale == 1 ? "F" : "C"
break;
case 3:
map.name = "illuminance"
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = "lux"
break;
case 5:
map.name = "humidity"
map.unit = cmd.scale == 0 ? "%" : ""
break;
case 0x1E:
map.name = "loudness"
map.unit = cmd.scale == 1 ? "dBA" : "dB"
break;
createEvent(map)
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
result
