Mim-h04en | ae260rnwseg
Hi, when will be possibile to set temperature (thermostatCoolingSetpoint) in the automation tab?
As now only torun on-off is possible but turning off and on the power pump for heating houses is a bad practice as the system will need to make water hot again and again.
Can you do it with a scene? Then use the scene in a Routine.
Thanks for for replay.
Nope, temperature setting is not available.
You may choose to switch on or off.
This must be related to your thermostat capabilities. I can set mode (heat/cool), fan mode (auto/on/off), and heating and cooling temps on my Honeywell thermostat with ST automations.
MIM-04en does not seem to support any other automation except on/off, it does not even support starting just heating or just dhw, only both. Does someone know how best to contact samsung. Making this work must be hours, max days of work of 1 programmer and it would help so much those who have solar panels, or leave house often, so they can optimize their consumption. Is there maybe a different wifi module, from other company that supports this?
This forum was set up a number of years ago so that customers could help other customers with the SmartThings home automation platform. It’s not actually an official support channel and very few Samsung employees visit here.
Instead, try the official Samsung support community, which is monitored by employees. They may just send you back over here if they think it’s about how to use the app, but it’s worth a try.
