Hi try to add a wemo or Sonos device and I have a message , The hub memory’s is full , delete some device …
That what I did , and the message is always there !!!
just curious…
- which hub?
- how many devices are installed?
- and definitely how many Edge Drivers do you have installed if you are using them?
On snap… I was wondering about that and memory being the root cause of performance issues im having. I know the last firmware update supposedly fixed a memory leak bug but im not sure.
@Sylvain I’m at 270 connected devices, with several more virtual, and my hub is v2 version. Im curious what ST support will find out.
Tagging @nayelyz
Device is around 140.
Hub v2
Driver 44
Ok then something else may be up. I just added a new connected device yesterday and it went fine. Try discovery using scan nearby and not by device or manufacturer/brand.
I just bought a tuya zigbee 4 button ts004f , a know working button , I already have one from the same seller and it working very good .
Try to add the button , pairing process is working and the button act like if SmartThings found it but it never show up in the app !
Don’t know if it could be related .
I can add already pair device that as loose connection.
Do you have a room at the bottom of your list called unknown, or unassigned (I can’t remember which one it is)?
No Room Assigned ?
Yes and button is not there
Just as a data point, I’m at 339 devices, 200 routines/scenes and no memory issues noticed. V2 hub.
I was digging how could I add my device and check Wich firmware my hub is , I’m on 44.09 , so I went back scan my tuya button ts004f and now SmartThings finds them, also other tuya temp sensor but I always have that message of memory full when adding by brand wemo or sonos
Thanks for the tag, @johnconstantelo
But, this is the Customer Support team’s area. They should be able to analyze the Hub situation further to understand what’s going on.
So, @Sylvain, please contact them and explain your situation as detailed as possible:
Through the SmartThings Web page
- Enter this page
- Click on “Support” in the upper-right corner
- Check if the URL includes your region. For example,
en-ushere:https://support.smartthings.com/hc/en-us - At the bottom, select “email” and describe your issue as detailed as possible.
- Click on “submit”
From the ST app
- Open the SmartThings app
- Go to the menu tab at the bottom-right corner.
- On this page, select the option “contact us” and then go to “Report a problem”
- Accept the generation of logs, fill up the form describing your issue as detailed as possible, and screen captures of the issue always help.
- Click on “submit”. The Customer team will receive this info.
Via email
US: 1-866-813-2404
US: support@smartthings.com
UK support 0333 0000333
UK: support@smartthings.co.uk
CA: support@smartthings.ca
I have found that bug while trying to link 4 tuya device , since the last hub update 44.09, I can link them now .
The other problem have to be fix by smartthigs , I have done what I was looking for .
Thank you
I’m also having this problem. Memory full with 102 devices and 40 drivers.
Edit:
Also my hub keeps finding devices that doesn’t have any drivers anymore. I deleted 8 obsolete drivers and 10 devices. Rebooted and power cycled the hub. No change.
