I just purchased one of these MH9 Z Wave Multi-sensor CO2/Temperature/Humidity
http://www.mcohome.com/show_list.php?id=15&sid=51
Like an Idiot, I didn’t think to check if it had a device handler available. Hardware installation was a breeze and It connects to my Z Wave fine. But now I need a device handler!
Being Chinese I can’t get a sensible response to date from the manufacturer although the datasheet does specify these supported classes.
COMMAND_CLASS_BASIC
COMMAND_CLASS_SENSOR_MULTILEVEL_V5
COMMAND_CLASS_CONFIGURATION
COMMAND_CLASS_NOTIFICATION
COMMAND_CLASS_ASSOCIATION
COMMAND_CLASS_MANUFACTURER_SPECIFIC
COMMAND_CLASS_VERSION
Has anyone else had experience with this device (MH9)!
Does anyone have a device handler!
Is the info above enough to write a device handler!
Its a nice looking device and being mains powered with the correct pitch screws it can replace an existing UK wall switch (As long as you have a neutral) which makes it very easy to install.
