Mc Zigbee Window Treatment Edge Driver Issues
I’m wondering if it’s not a problem with the driver at all but in the default handler in the ST Lua libraries.
Similar discussion happening here.
Thank you @h0ckeysk8er, I appreciate you helping also!
Hi @Kevin_Espinosa
I don’t understand why the IKEA subdriver keeps running when that version of the driver is disabled for this device.
Please try to uninstall the device with the App and delete the stock driver and Mc driver from your hub.
Once deleted, install this new version of the driver and pair the device again.
 Name         Zigbee Window Treatment Mc
 Version      2023-04-29T08:11:14.666687268
I followed all these steps, even going so far as to unenroll from your channel and then re-enroll. Still didn’t work. Here is the updated log:
35 e7070ea0-2ed9-4802-b7e7-5912a75f20fa Zigbee Window Treatment Mc
? Select a driver. 35
connecting… connected
2023-04-29T12:08:04.757736554+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T12:08:04.774348554+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-29T12:08:04.782678554+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment → yoolax window shade
2023-04-29T12:08:04.783523221+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:05.127429554+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T12:08:05.911528555+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T12:08:05.912508555+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x82, rssi: -101, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x59, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T12:08:06.003316888+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:06.167181222+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T12:08:06.168363888+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x82, rssi: -92, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x59, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T12:08:06.373674222+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:06.473220222+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T12:08:06.474473222+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x7E, rssi: -96, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x69, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4C > > > >
2023-04-29T12:08:06.681977222+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T12:08:06.683533555+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T12:08:06.701813222+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:38}}
2023-04-29T12:08:06.715418555+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:30.541706567+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T12:08:30.543099900+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x4E, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x64 > > > >
2023-04-29T12:08:30.585237233+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T12:08:30.586322900+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-29T12:08:30.591708233+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:100}}
2023-04-29T12:08:30.607319900+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“open”}}
2023-04-29T12:08:30.637202567+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:30.638054233+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:31.146482234+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T12:08:31.148101234+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x5A, rssi: -94, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4E > > > >
2023-04-29T12:08:31.459400567+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T12:08:31.465658567+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T12:08:31.471014234+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:39}}
2023-04-29T12:08:31.494267234+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
2023-04-29T12:08:32.652873234+00:00 DEBUG Zigbee Window Treatment Mc Smartwings Window Treatment device thread event handled
@Kevin_Espinosa
What I see now in the logs, driver works correct:
  • You click Open command in the App
  • The command to open 100% is sent to the device
  • The device sends blind position 100% and value level = 100% and status = Open is emitted.
Up to here everything is now correct.
If the blind has closed instead of opening then the motor is connected backwards.
If the device has a remote that works correctly, the device may have some setting to reverse the operation.
Have you tried, as I asked you, to execute open or close a % instead of the open or close command?.
I need to know how executing a level command
@orangebucket
Please, could you tell me which DTH you mean?
I can’t find the DTH
I’ll check when I am able to get back home. Thanks, again!
Try installing this new driver version, that send % inverted for open and close command same DTH
 Version      2023-04-29T13:40:31.048251187
@Mariano_Colmenarejo we have progress (I think)! I installed the new driver and here is how everything works now, there is just one problem (the close command is opening):
Command: Open → opens blinds
Command: 0% → opens blinds
Command: Close → OPENS blinds
Command: 100% → closes blinds
I can run new logs, do you want to see it with a “close” command sent?
Here is the CLI for a 100% command (which properly closed the blinds) followed by a “close” command (which opens the blinds):
2023-04-29T14:50:09.771701610+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T14:50:09.782676276+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{“shadeLevel”:100},“capability”:“windowShadeLevel”,“command”:“setShadeLevel”,“component”:“main”,“positional_args”:[100]}
2023-04-29T14:50:09.801518276+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-29T14:50:09.802621610+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:10.671230610+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:10.672205277+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x64, rssi: -103, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x61, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T14:50:10.683068943+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:10.701085943+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:10.701918943+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x5E, rssi: -104, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x61, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T14:50:10.710575277+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:11.143047610+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:11.144458943+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x60, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x37, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4A > > > >
2023-04-29T14:50:11.197648610+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:50:11.198497277+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:50:11.200306277+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:37}}
2023-04-29T14:50:11.208888610+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:22.997801949+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T14:50:35.289085622+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:35.290151622+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x96, rssi: -81, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x39, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x64 > > > >
2023-04-29T14:50:35.338979622+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:50:35.339808622+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-29T14:50:35.351764955+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:100}}
2023-04-29T14:50:35.393186622+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“open”}}
2023-04-29T14:50:35.439166288+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:35.446675288+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:35.721405289+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:35.722239622+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x92, rssi: -83, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4C > > > >
2023-04-29T14:50:35.800593955+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:50:35.804258289+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:50:35.806015955+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:38}}
2023-04-29T14:50:35.919373289+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:37.437760623+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:41.285003291+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T14:50:41.314732291+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-29T14:50:41.332571291+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment → yoolax window shade
2023-04-29T14:50:41.333405291+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:41.613114291+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:41.614521958+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x92, rssi: -89, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x62, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T14:50:41.653070958+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:41.689527291+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:41.690904291+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x90, rssi: -85, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x62, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T14:50:41.720597625+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:42.031023958+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:50:42.032664625+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x88, rssi: -83, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x48 > > > >
2023-04-29T14:50:42.090995958+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:50:42.094624625+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:50:42.099069958+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:36}}
2023-04-29T14:50:42.130937958+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:50:52.999398297+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T14:51:06.132318636+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:51:06.134108303+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x92, rssi: -81, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x00 > > > >
2023-04-29T14:51:06.213311636+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:51:06.214141636+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-29T14:51:06.215851636+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:0}}
2023-04-29T14:51:06.256938970+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closed”}}
2023-04-29T14:51:06.290442636+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:51:06.299214636+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:51:06.584827970+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:51:06.595323303+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x84, rssi: -84, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4C > > > >
2023-04-29T14:51:06.690618303+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:51:06.696180970+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:51:06.697911637+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:38}}
2023-04-29T14:51:06.718490637+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:51:08.298627637+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
Yes, please
I have the CLI for both a 100% command and a “close” command above. Here is just the close command:
2023-04-29T14:59:32.711459970+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T14:59:32.734448970+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-29T14:59:32.742679637+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment → yoolax window shade
2023-04-29T14:59:32.743517304+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:33.878849638+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:59:33.882690638+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x96, rssi: -87, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x68, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T14:59:33.891779971+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:33.925428971+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:59:33.926262971+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x96, rssi: -84, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x68, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T14:59:33.935387638+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:34.331419638+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:59:34.332603638+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x8E, rssi: -82, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x42, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x48 > > > >
2023-04-29T14:59:34.364326971+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:59:34.365172971+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:59:34.366893305+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:36}}
2023-04-29T14:59:34.375028971+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:53.091043313+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T14:59:58.558276983+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:59:58.559460983+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x92, rssi: -82, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x43, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x00 > > > >
2023-04-29T14:59:58.645554316+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:59:58.664994316+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-29T14:59:58.666315983+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:0}}
2023-04-29T14:59:58.702400649+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closed”}}
2023-04-29T14:59:58.837752983+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:58.838745316+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T14:59:58.921156316+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T14:59:58.926489650+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x8A, rssi: -82, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x44, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4C > > > >
2023-04-29T14:59:58.987160650+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment
2023-04-29T14:59:58.988143983+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-29T14:59:59.000464983+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:38}}
2023-04-29T14:59:59.017913983+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:00:00.791271317+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
What steps do you do to install the driver with the CLI?
You say that you have installed it, but in the logs I don’t see the changes that I have made in the driver.
Open a new CLI window different from logcat.
In this window perform the installation of the driver and when it is installed, you will see in the logcat window, after several seconds, how it is installed. Do not handle the device until the installation is complete.
Could you send me the log of the installation of this driver?
 Version      2023-04-29T15:14:31.691362518
Here is the driver install:
40 Zigbee Window Treatment Mc e7070ea0-2ed9-4802-b7e7-5912a75f20fa
? Select a driver to install. 40
driver e7070ea0-2ed9-4802-b7e7-5912a75f20fa installed to hub 8dee4e46-ddae-4693-b259-c65c60cde6c6
LogCat window shows the install:
2023-04-29T15:22:53.459201718+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T15:23:17.161426063+00:00 TRACE Zigbee Window Treatment Mc Received event with handler driver_lifecycle
2023-04-29T15:23:28.122500402+00:00 WARN Zigbee Window Treatment Mc Unexpected filesystem lookup for capability stse.reverseCurtainDirection
2023-04-29T15:23:28.141528402+00:00 WARN Zigbee Window Treatment Mc Unexpected filesystem lookup for capability stse.softTouch
2023-04-29T15:23:28.188498068+00:00 WARN Zigbee Window Treatment Mc Unexpected filesystem lookup for capability stse.reverseRollerShadeDir
2023-04-29T15:23:28.376166068+00:00 PRINT Zigbee Window Treatment Mc <<<<< Yoolax subdriver: set_window_shade_level >>>
2023-04-29T15:23:28.377192735+00:00 PRINT Zigbee Window Treatment Mc <<<<< level = nil
2023-04-29T15:23:28.378495068+00:00 PRINT Zigbee Window Treatment Mc <<<<< Yoolax subdriver: set_window_shade_level >>>
2023-04-29T15:23:28.379671735+00:00 PRINT Zigbee Window Treatment Mc <<<<< level = nil
2023-04-29T15:23:28.754724735+00:00 TRACE Zigbee Window Treatment Mc Setup driver zigbee_window_treatment with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee_window_treatment
default_handlers:
infoChanged:
doConfigure:
added:
driverSwitched:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Vimar Zigbee Window Shades
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler
default_handlers:
added:
doConfigure:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Roller Shade Handler
default_handlers:
infoChanged:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Window Treatment Version Handler
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Feibit Device Handler
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → SOMFY Device Handler
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → ikea window treatment
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Rooms Beautiful Device Handler
default_handlers:
infoChanged:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → AXIS Gear Handler
default_handlers:
added:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → AXIS Gear Handler → AXIS Gear Handler with version
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → yoolax window shade
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee_window_treatment → Tuya Device Handler
default_handlers:
added:
child_dispatchers:
2023-04-29T15:23:28.811989402+00:00 TRACE Zigbee Window Treatment Mc Setup driver zigbee_window_treatment with Capability handlers:
CapabilityCommandDispatcher: zigbee_window_treatment
default_handlers:
windowShadeLevel:
setShadeLevel
refresh:
refresh
windowShade:
close
pause
open
windowShadePreset:
presetPosition
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Vimar Zigbee Window Shades
default_handlers:
windowShadeLevel:
setShadeLevel
windowShadePreset:
presetPosition
windowShade:
close
pause
open
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler
default_handlers:
windowShadeLevel:
setShadeLevel
refresh:
refresh
stse.deviceInitialization:
setInitializedState
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Roller Shade Handler
default_handlers:
windowShadeLevel:
setShadeLevel
windowShade:
open
close
stse.shadeRotateState:
setRotateState
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Window Treatment Version Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Feibit Device Handler
default_handlers:
windowShadeLevel:
setShadeLevel
windowShadePreset:
presetPosition
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → SOMFY Device Handler
default_handlers:
windowShadeLevel:
setShadeLevel
windowShadePreset:
presetPosition
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → ikea window treatment
default_handlers:
windowShadeLevel:
setShadeLevel
windowShadePreset:
presetPosition
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Rooms Beautiful Device Handler
default_handlers:
windowShadeLevel:
setShadeLevel
windowShade:
open
close
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → AXIS Gear Handler
default_handlers:
windowShade:
close
pause
open
refresh:
refresh
windowShadePreset:
presetPosition
windowShadeLevel:
setShadeLevel
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → AXIS Gear Handler → AXIS Gear Handler with version
default_handlers:
windowShade:
close
pause
open
refresh:
refresh
windowShadeLevel:
setShadeLevel
windowShadePreset:
presetPosition
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → yoolax window shade
default_handlers:
windowShade:
open
close
child_dispatchers:
CapabilityCommandDispatcher: zigbee_window_treatment → Tuya Device Handler
default_handlers:
child_dispatchers:
2023-04-29T15:23:28.813714069+00:00 TRACE Zigbee Window Treatment Mc Setup driver zigbee_window_treatment with Zigbee handlers:
ZigbeeMessageDispatcher: zigbee_window_treatment
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Vimar Zigbee Window Shades
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Basic, attribute: ApplicationVersion
ZclClusterAttributeValueHandler: cluster: Basic, attribute: 0x0404
ZclClusterAttributeValueHandler: cluster: Basic, attribute: 0x0401
ZclClusterAttributeValueHandler: cluster: AnalogOutput, attribute: PresentValue
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Roller Shade Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Aqara Window Treatment Handler → Aqara Window Treatment Version Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Feibit Device Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → SOMFY Device Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: PhysicalClosedLimitLift
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → ikea window treatment
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Rooms Beautiful Device Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → AXIS Gear Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Basic, attribute: SWBuildID
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → AXIS Gear Handler → AXIS Gear Handler with version
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → yoolax window shade
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee_window_treatment → Tuya Device Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: 0xF000
ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: 0xF001
ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: 0xF003
global:
cluster:
zdo:
child_dispatchers:
2023-04-29T15:23:29.475112736+00:00 TRACE Zigbee Window Treatment Mc Zigbee Device: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf
Manufacturer: Smartwings Model: WM25/L-Z
[1]: Basic, PowerConfiguration, Identify, Groups, Scenes, WindowCovering
2023-04-29T15:23:29.476580736+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T15:23:29.477809402+00:00 TRACE Zigbee Window Treatment Mc Received event with handler _resync
2023-04-29T15:23:29.492888069+00:00 TRACE Zigbee Window Treatment Mc Received event with handler environment_info
2023-04-29T15:23:29.529851402+00:00 TRACE Zigbee Window Treatment Mc Received event with handler environment_info
2023-04-29T15:23:29.596852402+00:00 DEBUG Zigbee Window Treatment Mc Z-Wave hub node ID environment changed.
2023-04-29T15:23:29.602337069+00:00 TRACE Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received unhandled lifecycle event: init
2023-04-29T15:23:29.611146402+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2
@Kevin_Espinosa
Seems to have installed fine
Can you try the open and close commands from the app?
Here is an open command followed by a close command:
2023-04-29T15:31:58.809830443+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T15:32:00.484577443+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T15:32:00.806425110+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-29T15:32:00.810063110+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment → yoolax window shade
2023-04-29T15:32:00.811384777+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:01.665681443+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T15:32:01.667080777+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x92, rssi: -87, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x15, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T15:32:01.711227443+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:01.742687443+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T15:32:01.743926777+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x98, rssi: -87, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x15, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T15:32:01.804541777+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:28.816634113+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-29T15:32:44.402822649+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-29T15:32:44.405704316+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-29T15:32:44.407415316+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment → yoolax window shade
2023-04-29T15:32:44.423554316+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:45.821425649+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T15:32:45.822607316+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x6E, rssi: -88, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x16, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: SUCCESS > > >
2023-04-29T15:32:46.093287649+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:46.094542983+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-29T15:32:46.095712316+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 93116a4c-d61c-4bfb-a1e9-dfeea38135cf [0xBC7B] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC7B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x6A, rssi: -96, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x16, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x05, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-29T15:32:46.125993316+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-29T15:32:58.810869651+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
@Kevin_Espinosa
 Version      2023-04-29T15:52:54.411669853
