I use three Qubino Z-Wave Plus Flush Shutter DC (ZMNHOD3) controllers to control 3 water valves. They have been in operation for about 2 years now. On April 21, 2023 I noticed an issue with water running when it should not be, and today I found out a water valve I had closed using the ST app is actually open now, and opening the valve using the app closed it.
I suspect that a recent ST update may have reversed the open/close operation. Is any one else experiencing similar issues?
I have a Hub V3 with firmware version 000.047.00011
Annoyingly Im having the same issue with a window shutter… has worked fine for swveral years and now out of the blie has reversed after an update and cannot find a way to revert to the opd ST driver prior to April where it worked fine…
Imagine it must be affecting alot of people so surprised there is still no fix…
