Mc Zigbee Window Treatment Edge Driver Issues
@Mariano_Colmenarejo here is the API+:
Key Value
Name window-treatment-battery
Mfg Name SmartThingsCommunity
Mfg Code Smartwings
Model WM25/L-Z
ocf Type oic.d.blind
Category Blind
Room Theater Room
Presentation ID f63d619a-609c-3ac1-91bc-d75ea1eda849
Type ZIGBEE
Parent ID 8dee4e46-ddae-4693-b259-c65c60cde6c6
Parent Name SmartThings Hub
Driver ID e7070ea0-2ed9-4802-b7e7-5912a75f20fa
Driver Name Zigbee Window Treatment Mc
EUI 0C4314FFFE8AB0B1
Network ID 4011
Provisioning State NONFUNCTIONAL
Local Execution yes
You can force the driver to update by doing an install with the CLI.
Good to know, thank you!
Modified manufacturer in this driver version. Now it must works fine
You can install new version with CLI command smartthings edge:drivers:install
 Version      2023-04-28T16:41:01.425366747
- id: "Smartwings/WM25/L-Z"
    deviceLabel: Smartwings Window Treatment
    manufacturer: Smartwings
    model: WM25/L-Z
    deviceProfileName: window-treatment-battery
@Mariano_Colmenarejo new driver updated and somehow it’s still reversed
Could you send logs, please?
@Mariano_Colmenarejo I sent a close and then an open so you could see both:
36 e7070ea0-2ed9-4802-b7e7-5912a75f20fa Zigbee Window Treatment Mc
? Select a driver. 36
connecting… connected
2023-04-28T19:57:44.898149642+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T19:57:44.913183188+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-28T19:57:44.924070204+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T19:57:44.947757712+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:57:46.877416934+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:57:46.934525268+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x64, rssi: -100, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-04-28T19:57:46.948335268+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:57:47.014441935+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:57:47.026630601+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x5A, rssi: -95, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T19:57:47.044600268+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:57:47.352013601+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:57:47.352993601+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x6C, rssi: -91, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x57, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x54 > > > >
2023-04-28T19:57:47.407491601+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:57:47.408344601+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T19:57:47.412360268+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:42}}
2023-04-28T19:57:47.419204268+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:57:57.479417273+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T19:58:11.501438613+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:11.502624280+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x58, rssi: -95, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x58, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x64 > > > >
2023-04-28T19:58:11.582300613+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:58:11.583167613+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T19:58:11.584857613+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T19:58:11.586185946+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closed”}}
2023-04-28T19:58:11.603269946+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:0}}
2023-04-28T19:58:11.623982613+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:12.013328280+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:12.014737280+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x4E, rssi: -91, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x59, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x50 > > > >
2023-04-28T19:58:12.066754613+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:58:12.067608613+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T19:58:12.071372946+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:40}}
2023-04-28T19:58:12.085240613+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:14.514880948+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T19:58:14.662851281+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-28T19:58:14.664848614+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T19:58:14.711016281+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:14.941422281+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:14.942395614+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x64, rssi: -94, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2E, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-04-28T19:58:14.963974615+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:14.970306948+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:15.008556281+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x48, rssi: -98, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2E, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T19:58:15.020974615+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:15.439586615+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:15.440680281+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x50, rssi: -93, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4C > > > >
2023-04-28T19:58:15.491743615+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:58:15.492591615+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T19:58:15.494282948+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:38}}
2023-04-28T19:58:15.502439615+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:27.477357620+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T19:58:39.861444626+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:39.862627960+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x68, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x00 > > > >
2023-04-28T19:58:40.133801627+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:58:40.134988960+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T19:58:40.141495293+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T19:58:40.142678960+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“open”}}
2023-04-28T19:58:40.298426960+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:100}}
2023-04-28T19:58:40.410914627+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T19:58:40.411915960+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T19:58:40.413178960+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x5C, rssi: -94, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x50 > > > >
2023-04-28T19:58:40.520602293+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T19:58:40.524229960+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T19:58:40.531493293+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:40}}
2023-04-28T19:58:40.596282627+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
Could you send me a link to the DTH you are using?
Are you try send 100% or 0% level instead open or close?
I see in the logs, your device not support commands 0x00 (open) and 0x01 (close)
Hi @Kevin_Espinosa
Try with this driver version
 Version      2023-04-28T20:50:46.741831439
Still reversed. I wasn’t using a specific DTH, just paired to SmartThings and it all worked. I just bought the blinds a month ago. It disconnected from SmartThings last week and I reinstalled and it picked up the edge driver.
Please, send the logs to see changes in the driver.
Are you click in open, close or select level 0% or 100%?
Clicking open/close in the SmartThings app. Also tried with Alexa commands open and closed. I’ll send logs again shortly
@Mariano_Colmenarejo updated logs
2023-04-28T21:47:29.031800562+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T21:47:32.907951564+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T21:47:32.938667230+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-28T21:47:32.940136230+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T21:47:32.941351230+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:34.174076564+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T21:47:34.175575897+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x36, rssi: -106, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x05, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-04-28T21:47:34.284412564+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:34.326852898+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T21:47:34.328317564+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x42, rssi: -110, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x05, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T21:47:34.353842231+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:34.529451231+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T21:47:34.530713231+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x56, rssi: -97, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x02, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x51 > > > >
2023-04-28T21:47:34.546410564+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T21:47:34.563461564+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T21:47:34.565241898+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:41}}
2023-04-28T21:47:34.582263898+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:36.201245898+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T21:47:36.212583232+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x5E, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x03, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x09 > > > >
2023-04-28T21:47:36.271340898+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T21:47:36.272202232+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T21:47:36.273922232+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T21:47:36.281360565+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:91}}
2023-04-28T21:47:36.319766565+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closing”}}
2023-04-28T21:47:36.363511232+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:36.370109899+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:36.527768565+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T21:47:36.528608232+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x64, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x43 > > > >
2023-04-28T21:47:36.571890565+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T21:47:36.575026899+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T21:47:36.588164565+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:34}}
2023-04-28T21:47:36.602380565+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T21:47:38.384903233+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“partially open”}}
2023-04-28T21:47:38.431050566+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
This logs are for old driver version.
Please install this driver version with CLI
It’s odd. My driver is updated but the log isn’t showing that.
Uploading: 8D4E5128-5583-4BD1-8F9C-21DE9AD4F674.png…
2023-04-28T22:18:24.381795229+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T22:18:24.430060350+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-28T22:18:24.441028498+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T22:18:24.442255111+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:25.224815862+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:25.229615928+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x72, rssi: -94, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x13, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-04-28T22:18:25.251733981+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:25.252589075+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:25.258775500+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x70, rssi: -94, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x13, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T22:18:25.262215553+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:25.660533613+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:25.661926976+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x72, rssi: -94, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4D > > > >
2023-04-28T22:18:25.677815583+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:25.683055535+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T22:18:25.691599471+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:39}}
2023-04-28T22:18:25.694179094+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:29.352892826+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T22:18:29.374565009+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-28T22:18:29.403077672+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T22:18:29.403905730+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:29.454348927+00:00 INFO Zigbee Window Treatment Mc Doing health check read for [4011]:0102:0008
2023-04-28T22:18:29.461285413+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4011, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0008 > > >
2023-04-28T22:18:29.473863626+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:18:30.205062283+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:30.217590949+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x58, rssi: -94, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x14, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-04-28T22:18:30.224360616+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:30.325630616+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:30.326471949+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x46, rssi: -105, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x15, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0008, ZclStatus: SUCCESS, DataType: Uint8, CurrentPositionLiftPercentage: 0x64 > > > >
2023-04-28T22:18:30.384727283+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:30.385568949+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T22:18:30.404513949+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T22:18:30.419249616+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closed”}}
2023-04-28T22:18:30.444130283+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:0}}
2023-04-28T22:18:30.491693283+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:30.878247616+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:30.879655950+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x62, rssi: -96, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x11, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x47 > > > >
2023-04-28T22:18:30.956793950+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:30.958233616+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T22:18:30.960603616+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:36}}
2023-04-28T22:18:31.006044283+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:32.882886617+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:32.884318284+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x5A, rssi: -98, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x13, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x4F > > > >
2023-04-28T22:18:33.545306951+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:33.573450284+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T22:18:33.579729951+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:40}}
2023-04-28T22:18:33.591048951+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:34.411444618+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:34.412418618+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x56, rssi: -92, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x14, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T22:18:34.481710951+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:34.482560951+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:34.483776951+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x6C, rssi: -94, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x14, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x5E > > > >
2023-04-28T22:18:34.514638285+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:34.515501285+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T22:18:34.521410951+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T22:18:34.522633951+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:6}}
2023-04-28T22:18:34.570658285+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“opening”}}
2023-04-28T22:18:34.599206618+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:34.608549951+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:36.625776286+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“partially open”}}
2023-04-28T22:18:36.638458952+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:37.423524619+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:37.424711286+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x7A, rssi: -92, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x15, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, CurrentPositionLiftPercentage: 0x64 > > > >
2023-04-28T22:18:37.463214286+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:37.532075286+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: WindowCovering, attribute: CurrentPositionLiftPercentage
2023-04-28T22:18:37.551016620+00:00 PRINT Zigbee Window Treatment Mc <<<< Subdriver IKEA: current_position_attr_handler
2023-04-28T22:18:37.552404620+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“windowShade”,“capability_id”:“windowShade”,“component_id”:“main”,“state”:{“value”:“closed”}}
2023-04-28T22:18:37.824428286+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“shadeLevel”,“capability_id”:“windowShadeLevel”,“component_id”:“main”,“state”:{“value”:0}}
2023-04-28T22:18:37.871512953+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:38.371758953+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:18:38.386522953+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x80, rssi: -93, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x16, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x50 > > > >
2023-04-28T22:18:38.532598620+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:18:38.541391953+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T22:18:38.542715953+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:40}}
2023-04-28T22:18:38.608245953+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:18:59.473383630+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:19:29.450052978+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:19:59.473797325+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
Here is screenshot showing current driver
Yes it’s strange.
Install this version
 Version      2023-04-28T22:28:38.827730872
Nope, still didn’t work. But one interesting change. Even though the commands are still reversed it is accurately reporting the state as open and closed when appropriate.
Send me the logs and I’ll see it tomorrow, I’m going to sleep
Thanks, again, Mariano. I really appreciate all of your hard work here. I do in fact have the updated driver, so not sure why it isn’t showing that in the logs.
2023-04-28T22:42:29.793702284+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:42:37.909471919+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T22:42:37.943060919+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-28T22:42:37.944777252+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T22:42:37.992148252+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:42:38.948358253+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:42:38.957541919+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x84, rssi: -98, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x41, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-04-28T22:42:38.981725253+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:42:38.982574919+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:42:38.983790919+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x84, rssi: -91, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x41, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T22:42:38.993589253+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:42:59.797788262+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:43:29.821055610+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:43:59.807967291+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:44:29.815935972+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:44:59.819145653+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
2023-04-28T22:45:10.551019658+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T22:45:10.579149325+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“close”,“component”:“main”,“positional_args”:{}}
2023-04-28T22:45:10.580677658+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T22:45:10.581890992+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:11.452958325+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:45:11.454404659+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x78, rssi: -95, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x43, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-04-28T22:45:11.470808325+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:11.491261325+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:45:11.492096992+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x88, rssi: -88, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x43, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T22:45:11.500554992+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:12.549039659+00:00 TRACE Zigbee Window Treatment Mc Received event with handler capability
2023-04-28T22:45:12.618270659+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received command: {“args”:{},“capability”:“windowShade”,“command”:“open”,“component”:“main”,“positional_args”:{}}
2023-04-28T22:45:12.620100659+00:00 TRACE Zigbee Window Treatment Mc Found CapabilityCommandDispatcher handler in zigbee_window_treatment
2023-04-28T22:45:12.690782659+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:13.463550993+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:45:13.465208660+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x88, rssi: -95, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x44, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-04-28T22:45:13.512062993+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:13.512923993+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:45:13.514138660+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: WindowCovering >, lqi: 0x82, rssi: -92, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x44, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2023-04-28T22:45:13.516124326+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:13.934312326+00:00 TRACE Zigbee Window Treatment Mc Received event with handler zigbee
2023-04-28T22:45:13.935291660+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4011, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x86, rssi: -90, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x52 > > > >
2023-04-28T22:45:13.958773326+00:00 TRACE Zigbee Window Treatment Mc Found ZigbeeMessageDispatcher handler in zigbee_window_treatment → ikea window treatment
2023-04-28T22:45:13.963283660+00:00 INFO Zigbee Window Treatment Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2023-04-28T22:45:13.965041993+00:00 INFO Zigbee Window Treatment Mc <ZigbeeDevice: 0245cb8b-0904-4efe-87e6-bb87e608da2e [0x4011] (Theater Room Blinds)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:41}}
2023-04-28T22:45:13.974865660+00:00 DEBUG Zigbee Window Treatment Mc Theater Room Blinds device thread event handled
2023-04-28T22:45:29.844081001+00:00 DEBUG Zigbee Window Treatment Mc driver device thread event handled
