I’ve been trying to figure out why my Hello Home events (specifically Good Morning and Good Night) havent been firing (Good Morning) or have been firing way early (Good Night), and I THINK I’ve found a couple of MAJOR issues with SmartThings Time handling:
- If you set Good Morning to run “When Things Start Happening” between a certain time window (say 5-7AM), you may find that this does no longer run if you get up at 5am. The reason MAY BE because the time window was saved as 5-7AM Daylight Savings Time - and that time window WAS NOT corrected when the time changed. So it still waits until 5AM EDT (which is 6AM EST)…
Similarly for Good Night - “When Things Quiet Down” after 10PM is recorded as 10PM EDT, which is an hour later than 10PM EST.
To make matters worse, I found a CRAZY UI bug in the iOS app to boot: When setting times in a SmartApp, the time base used is NOT the time zone of the hub/devices, oh no-no - it’s the time zone WHERE YOU CURRENTLY ARE!!! So, in trying to fix this on my East Coast hubs from my hotel on the West Coast - all the times are OFF BY 3 HOURS!!!
Sorry for yelling, but these are just insane bugs to be dealing with…and to be fair, maybe it’s just me and I have screwed up SmartApps for some reason…so please - check for yourself. I found it easiest to use the IDE to figure out what times are actually being scheduled (by looking at the SmartApp parameters on my hubs)…
YMMV -
