I was wondering if there was any way to expose a lutron pico remote to smartthings without having to have it paired with another dimmer or switch? I would like to use just a pico remote as a button for different automations and to control devices. This may be a long shot but thought I would ask the community and see if this was a possibility.
Not through the official Integration.
There is a 2019 FAQ on this topic which covers possible unofficial methods, but notice anything that relies on groovy will go away once the groovy cloud goes away in a few months.
Method one in the FAQ, the one which uses a Lutron plug-in dimmer as a proxy, should still work, it’s just kind of clunky.
Ok thank you. I will read through it and ask if it is still even a workable solution.
Hubitat Works great with Lutron Devices, including Picos, I just don’t know how long there will be an integration between it and smartthings once the groovy cloud goes away. So then you might have to start getting into multi step integrations using MQTT or something, which could get very complicated.
