Pico remote without smart light dimmer switches?
The previous owner of our house installed Pico dimmer switches, and for where there wasn’t power for light switches he installed Pico remotes for those dimmers so that the lights could be turned on from multiple locations. He said he didn’t think the Pico dimmers were smart home capable, but the Pico remotes are. I looked at Lutron’s site and noticed that these dimmers aren’t listed as Caseta wireless, yet they have to be wireless for the Pico remote to work. This is where I’m getting confused! :slight_smile:
If the Pico remotes can be added to Smartthings surely I could then control the dimmers? Or do I need to add the dimmers as well? If they are wireless that doesn’t automatically assume they are smart capable, right?
Apology’s in advance if this is clear as mud - it’s taken me a day to work out what I have and get this far!
Thanks in advance to tolerating these questions! :slight_smile:
Steve
It can definitely get confusing, and I’m personally somewhat confused about what your actual question is because the topic header doesn’t seem to match what you wrote in your post. So let’s take a step back and just look at the basic facts about the Lutron pico remotes and see if that answers your questions. If not, at least we should have a foundation to work from. :smiling_face_with_sunglasses::level_slider::light_bulb:
Step 1: the Lutron/SmartThings Integration
Lutron Caseta dimmer switches can work with SmartThings, but only if you also have the Lutron SmartBridge or SmartBridge pro device. (That’s the same device you would need for HomeKit or Alexa or IFTTT integration, by the way.) that allows a Lutron system to communicate with the Internet and your local WiFi, which in turn opens up a bunch of additional integrations.
One smartbridge can support up to 50 Lutron devices.
You can buy the smartbridge by itself, but most people buy it in a “starter kit” which includes one smartbridge, one Lutron Caseta dimmer switch, and one Lutron pico remote.
Note that if you only have a Lutron Caseta master switch, it can only talk to other Lutron switches, which is probably what the person you were talking to you meant by saying it wasn’t “smart home capable.” That isn’t how I would describe it, but there is a real distinction. If you want to get integration with devices of other brands, then you also need the SmartBridge.
In the Amazon picture, the SmartBridge is the square white box sitting in front of the phone.
Step 2: the Pico
The pico is a battery operated device that can be either handheld or mounted on the wall in a frame that will make it the same size as a regular light switch. It comes in several different styles, both a dimmer style and one that just has two plain buttons, and even a 4 button style. You can even get custom engraving if you like.
Now we come to the first part where people get confused. A lot of contractors will say that the pico is “wireless” meaning it is battery operated and is not connected to the other light switches with traveler wires.
Home automation people will say that the pico is “wireless” meaning that it communicates by radio with other devices.
Both are true, but may have different significance in different contexts.
Step 3: how to Pico communicates with other devices
OK, pay attention to this part, because it won’t be confusing if you follow the full explanation, but it will be confusing if you just skip over this part.
A pico has three different possible ways of communicating with other devices.
3A. Direct communication to a specific Caseta master switch
If you don’t have the smartbridge device, you can still pair a pico to a specific Caseta master switch. So when you press a button on the pico, a message gets sent to that master, who will then do what it is asked. So you can use a pico either as a wallmount auxiliary switch for a master in a “virtual three-way” set up or as a handheld controller for the master switch and you don’t need any other devices or any other systems. But the pico can only talk to the specific master that it is paired to.
3B. Communication through the standard SmartBridge device
If you have the standard SmartBridge device, you can set up the official SmartThings/Lutron integration, and now the pico will communicate with the smartbridge. This allows it to control a wider set of Lutron Caseta switches. However, the pico will continue to be invisible to SmartThings. Using this method, smartthings will know when the master switch turns on but it doesn’t know that it turned on because the pico asked it to. And using this method you can’t use the pico button presses for anything else. Just turning on Lutron master switches.
That’s still fine for a lot of people, particularly those who are just looking for a wallmount three-way switch to go with the master.
https://support.smartthings.com/hc/en-us/articles/115000864766-How-to-connect-Lutron-Caséta-devices
3C. Communication via a “man in the middle” server to a smartbridge pro using an unofficial community – created integration
If you have a good technical background, and you get the smartbridge pro instead of the standard smartbridge, you can set up an additional device to act as a server and then you could make the Picos visible to SmartThings. Meaning when you press the button on the pico the smartbridge pro knows it, and that information gets passed along to smartthings. So then you can use a pico for anything that SmartThings can control. A lot of people like to have this functionality, but it is a lot more work to set up, and it is an unofficial integration.
Summary
So to answer the question posed by your topic title, yes, you can use the Picos on their own, but you have to set up another server as a “man in the middle”, you have to use the smartbridge pro model not the regular smartbridge, and you have to use the unofficial integration. All of which is a lot of work, and judging by your first post, isn’t really the question you wanted to ask anyway. :smiling_face_with_sunglasses:
To answer the other questions in your first post, if you use the official integration with SmartThings, you will be able to use the pico’s as the auxiliary wall switches in a “virtual three-way” but smartthings will continue to get all of its information based on the Master switch. And you will require the additional Lutron smartbridge device (the standard model is fine) in order to integrate the Lutron Caseta master switches with SmartThings. And with the official integration, the pico’s remain invisible to smartthings, so you can’t use their button presses for anything except controlling the Caseta master switch.
Did that help clear up any of the confusion?
I was about to give a 5 sentences answer then I realized… Just sit back and wait. :smile:
First off - thank you so much for the detail - and - holy cow, it makes more sense now! I actually purchased the smart bridge controller thinking I might need it, but couldn’t work out how to make it work with the Pico remote. Now that I know the master switch needs to be added it makes a lot more sense.
I’m going to re-read this when I get home (at the office now), but I believe I have a viable path forward. I really appreciate the detail.
Steve
Actually you can add a Pico without an actual switch as long as your smart bridge is set up.
Well said. Well said. Device limit is 50 though (staring at my 42 devices).
It will still be invisible to smartthings through the official Lutron integration, though. Unless something has changed very recently.
Whoops. I thought we were just talking generally, i.e. Lutron app.
Is there a way to use lutron pico remotes as buttons without adding any other hub?
No, the Lutron SmartBridge hub is required at a minimum, and even then, Pico Remotes are not supported by the official SmartThings ↔ Lutron integration. There is a community written solution for using Pico remotes, but if I recall correctly, a Raspberry Pi (or similar) is required as a man-in-the-middle solution. See this post above for more details.
Thanks. Is there any similar to the lutron pico remotes that work directly with smartthings?
Does the Aeon Labs AL001-B-US,Black,US,AL001 Touch Panel One Button work as a anithing button with smartthings?
or the Insteon 2342-242 Mini Remote Switch, On/Off?
How about the official ST Button?
https://www.amazon.com/Samsung-SmartThings-GP-U999SJVLEAA-One-Touch-Appliances/dp/B07F8ZFFQK/ref=sr_1_2?gclid=EAIaIQobChMI3J-Xodz75AIVxp-zCh1rawgrEAAYASAAEgKKF_D_BwE&hvadid=153691366947&hvdev=c&hvlocphy=1021374&hvnetw=g&hvpos=1t1&hvqmt=b&hvrand=12944426540522204041&hvtargid=kwd-255971991056&hydadcr=25913_9539995&keywords=smartthings+button&qid=1569955579&sr=8-2
The Aeon device you mention above is not ‘smart’. It is just a button that must be used with another Aeotec product.
Insteon is a completely different protocol that is not compatible with SmartThings.
I have never used any of the devices you have mentioned. I actually use Pico Remotes via my Lutron SmartBridge Pro2, connected to my Hubitat Elevation home automation hub. Hubitat has built-in support for the Pico remotes, as well as the rest of the Lutron switches, dimmers, and fan controllers.
Search for compatible Button Controllers within the SmartThings ecosystem. These will usually need to be Zigbee or Z-Wave devices to work with SmartThings.
Yes the official ST button works perfect, I have 3 and they work great, but they don’t look very good on the wall.
Insteon devices don’t, but there are a number of zwave and zigbee devices which do, and there are also some Bluetooth and Wi-Fi devices which can work in a cloud to cloud integration.
See the buttons FAQ. The FAQ is intended to only have one or two posts per device and usually will link to a conversation thread about each device. So if you have any follow-up questions on a specific device, either go to the conversation thread about it or come back here and ask. Don’t add additional posts to the FAQ. Thanks! :sunglasses:
The FAQ posts should list whether the device is for the US or the UK and whether it is battery powered or Mains powered. So read the descriptions carefully to find something that matches what you are looking for.
FAQ: Full list of buttons and remotes confirmed to work with SmartThings
By the way, most of the devices in the buttons FAQ will require custom code. But there are a few on the official compatibility list that will work out of the box.
In particular, the Eaton Cooper battery powered zwave switch is very popular. It looks like a regular switch. But it is somewhat more expensive than some of the other options in the buttons FAQ.
(Eaton is the company, Cooper is the division, and aspire is the model line. You can find the same device listed under any of those three names at different retailers.)
747C1C5D-90C9-4A1E-9DF6-96C083BAE08B
Heres the updated scoop!
  • First off, Many people don’t know a few of these awesome Pico remotes even exist:
    https://diysmartlighting.com/caseta-wireless-pico-remotes. - see EVERY pico here
  • Now up to 75 devices can be put on Caseta Wireless,
    -there is now a new type repeater to extended coverage that works with dimming module repeater as well…
    -now a occupancy/ vacancy sensor is available for Caseta Wireless…
Go here to find it all easily with quick specs: https://diysmartlighting.com/caseta-wireless
Now unleash your Caseta Wireless System to its full potential
Enjoy!
None of those picos are visible to smartthings through the official integration, though. :disappointed_relieved:
Ya i know… its super annoying that the picos cant work with other smart hubs other then Home Assistant (HA)… but from what i see its very complicated to get started… im curious if wink 2 hub has anything more to offer as it works directly with the switches (using the rf tech) and can be used instead of caseta hub but i dont know all the details
Talked to this guy that set it up so the pico remote was a power on/off with raise/lower for his smart tv using the HA system
Anyway maybe someday theyll unlock there system for us… but one thing nice is for lighting purposes only, its nice to have a few of those remotes. one is basically a keypad (3 different scenes and and off)… I personally had no idea for awhile and was so happy when i found out about it, as it adds a nice feature to the room
It’s not complicated at all. :sunglasses: They work fine with hubitat and they used to work fine with both Wink and the Staples hub which was discontinued a few years ago.
As long as you are using the “pro“ version of the Lutron smartbridge, they have an open API and you can telnet into it. Just not from SmartThings.
Lutron Pico - 🛎️ Get Help - Hubitat
