@RottenMutt
Sorry if I didn’t state my intent clearly enough. Let me clarify.
I have a collection of Ikea Tradfri smart outlets, which are honestly painfully large, but from what I have seen most smart plugs / outlets are really too big to play nice with other outlets.
My application is for the master bedroom, and the guest bedroom I have 2 night stands that I need to provide power for the following items.
#1. Table lamp. This is controlled by the Tradfri.
#2. Medical devices. I am 50, and younger than most of our generation in the family. There are a LOT of CPAP machines and the like to be powered.
#3. At least one of these will have to power an Amazon Echo device, in the guest room and echo dot, in the master a full echo…
#4. USB charging ports for phone, bluetooth headset, and Fitbit.
The concept is I want to attach a power strip / surge supressor to the back side of each night stand, and route the power from there.
I have lsst the link to the most interesting one, which is my fault. It had sideways outlets so if you look at it, all the ground pins line up in a row down the middle of the strip, there was one that was wide spaced from the others, there were a total of 4 110v US ports, and 4 USB charging ports on it, and it was black…
It was very much like the one that @JDRoberts linked above, but black, and the power ports rotated 90 degrees. If I can figure out the link for it, I will post it like I said… It looked ideal for what i am doing. 1 of these per night stand…
Honestly I might have to go with the short extension cords anyway, the Echo Dot power block is pretty bulky too, at least for the 2nd generation Echo Dot…
