Learned that the Kichler z-wave dimmer - 12387 does not connect to the SmartThings hub. Support suggested I look to the community for a devise handler - Bueller?
Thanks for the help!!
If it won’t connect at all, not sure a device handler will help it. Usually if it sees something it will grab the closest handler it can find and connect it as that. I think you need to get there before a handler will do anything.
It’s an unusual form factor, but when added to a third-party Z wave network like when controlled by a smartthings hub, it’s just a dimmer switch. You shouldn’t need a special device type handler.
So as @doncaruana mentioned, the first thing is just to see if you can add it to the SmartThings network.
Because of the unusual form factor, this device is a little more complicated – – you’re going to need a paperclip to hit the reset button.
The exact instructions are under “option five” in the user manual for this device:
http://www.kichler.com/media/documents/instruction_sheets/IS-12357.pdf
If it was previously paired to another network, or if you think you might’ve got a partial pairing, you may need to issue a general exclusion first. You’ll need the instructions from the SmartThings support knowledge base for what to do on the SmartThings side. On the Kichler side, use the “Reset Z-Wave Dimmer” instructions at the very end of the user guide.
So,
Use the “reset z-Wave” instructions in the Kichler user manual for what buttons to push on the Kichler device to complete the exclude.
After that it should work as a vanilla dimmer switch. This device also has the capability of acting as a primary controller to control other Z wave dimmer switches, but it won’t work well that way when it’s on a SmartThings network so just let smartthings be the primary controller and use this as a dimmer switch.
As a dimmer switch, it only has the basic features, which is why you can use the generic device type handler.
Thanks - got it working!!
