I bought the Lightify 2 button dimmer switch and press 1 and 2 along with hold 1 work fine. When I use long press 2 it shows up in the log, but not as a long press or any press at all. I tested this with webcore and the smartlight app and neither register it as a long press. I already unpaired and repaired the button.
Is my button broken? It is still within the exchange window. Or does it seem like a software bug? The fact that a quick press of button 2 works has me at a loss and when I searched I couldn’t find this exact issue.
I have three of these switches and the long press on button 2 used to work with both CoRE and the Button Controller+ smart app. No longer though, the short press works fine but the long press just doesn’t register.
Having all three fail in exactly the same way seems more like a software issue than a hardware one to me but regardless I haven’t found a fix yet.
Good to know. Thanks for the heads up!
Maybe Ill upgrade once they go back down to $50 on sale.
Did you have to rebuild everything from scratch? I have almost 40 things and a
ton of pistons and starting over will be a huge pain.
Yeah, unfortunately. The Zigbee stuff was all pretty simple, but the z-wave things were a huge PIA. It took about 2 hours to get things usable again. I have about 30 things. Not nearly as bad as I thought it would be. I’d just started with pistons though, so I only had 2 of those. Plus I cleaned up a bunch of abandoned device handlers and smartapps that I’d accumulated playing around with stuff.
