Logitech Harmony (Connect) Updated?
They put back the harmony trigger App in the marketplace, probably as a workaround.
So if the harmony connect section about activities/triggers crashes for you, then only use the connect smart app to connect the hub. Don’t touch the fields that list activities or triggers. Then after you’re done, go to the marketplace and get the triggers app to set up the triggers.
You can follow the steps in the old FAQ:
