Hi,
I’m just trying to add my Logitech Harmony Hub to SmartThings using the new SmartThings app, but Logitech is not an option. I feel like I’m missing something so obvious here. I’m following the instructions found here for the new app:
I can add Harmony Connect using the SmartThings Classic app, but my Harmony activities do not work right. For example, when I turn an activity on, the virtual switch for the currently running activity doesn’t turn off.
Thanks, but when I turn an activity on, the virtual switch for the currently running activity doesn’t turn off. Is there any way to get my virtual harmony activity switches to work like my Harmony remote?
I’ve just had to redo my Harmony Hub activities because I got a new TV. I noticed it took several seconds for the Activity switch to turn on, and didn’t see it turn off when I selected a new activity. This is all on the Classic App.
That said, my hub’s been acting a little strange lately…not sure if the issue is at my end or Logitech’s.
Although Harmony is still not showing up in the new SmartThings app. I used the Classic app and followed the advise here to get the virtual activity switches to sync:
You can install Harmony in the new app, by doing the following:
In the IDE, Create a New Smartapp, From Template. In the list is Logitech Harmony (Connect). I believe you just need to save and Publish it and then it will be on the list of Smartapps in the ST apps.
Once the SmartApp is installed, open the ST app and go to the SmartApps section. Click on the app and it should launch into the setup app.
Why this is not included in the new app, I do not understand , but it is a valid workaround.
So, I followed your instructions. When I launch the setup for the Smart App on my IOS device, I get a “Something went wrong. Please try to install the SmartApp again.”. To fix it, I needed to go into the Smart App in the IDE and enable OAUTH.
Thank you.
i went ahead and deleted eveything (removed smartapp from IDE, removed ST from Harmony) killed all apps and tried everything again from scratch and that resolved the issue.
for others:
Go to IDE and remove any lingering devices / smartapps with the name (logitech harmony).
