Hello,
Im just starting out with a SmartThings hub.
I want to be able to use SmartThings to control my lighting.
I have been looking at the Lightwave RF range of retrofit light switches.
Do these work with SmartThings?
Hello,
Short answer: no
Longer answer: not really…
And in anticipation of your next question
read here:
Do the relays work with the Amazon Echo?
Yes, it just sees them as a switch/dimmer.
do these also work…I see this name mentioned a fair bit on here.
Or do I need this?
SmartThings supports z-wave and zigbee devices. Not all will work out of the box however, sometimes a custom device handler developed by a community member is necessary. I think the fibaro devices will work fine. One of those is a switch (on/off only) and the other is a dimmer; that’s up to you which one you want. Device compatibility/availability can be different in the US and UK though, FYI (I’m in the US).
You should take a look at the support website:
This one explains z-wave and zigbee:
Its for an outside light, so i just want it on or off.
The idea is to set up a geofence using the GPS on my phone so the outside light is on when i pull up at home.
I also want to use Alexa to turn the light on when i need it, when im at home
Not strictly true.
I have numerous light switches and outlets working through ST.
My setup goes down the custom DH route via a Pi. It doesn’t have to be via a Pi though.
Search for LightwaveRF and there is a thread describing how to do it.
Some people are also using the Lightwave relay for curtains.
I know, hence “not really”. Not many people want to have to set up a man-in-the-middle solution.
Have you moved to RF2 with the status reporting?
Its a shame its a closed environment - i really like the look of their products.
i dont want to over complicate this…in my experience, the more complex it is, the less reliable it becomes.
I want to set it up, and have it work when i need it.
I’m sure you have, but just in case… have you considered an always-on smart-bulb rather than the Fibaro? They are much simpler to install and can do what you want.
I’m not sure which ones are rated for outside though (even covered) - it may depend on the range of temperatures you get where you live.
The lights I have are LED floodlights
This type of thing. They are switched from inside the house.
I’d be looking at a sonoff for that. I’ve just been building one into an LED floodlight at work, as a proof of concept, and so far it works well. The next step (for me) will be the custom firmware and test at home with smartthings.
thread here…
I just had a twitter reply from LightWaveRF today about smartthings intergration. They are not interested in playing nicely and obviously want a walled garden. Here is their tweet…
https://twitter.com/LightwaveRF/status/981109421748219905
