Lights will randomly dim
Hi everyone,
I’ve had GE Zwave Dimmer paddle switches for probably 8 years now. All of a sudden, when triggered by the motion routine, the dimmer will bounce all over the place but always ends at 100. It’s driving me mad trying to figure out why this is happening. It doesn’t happen every time. It mostly happens first thing in the morning and it doesn’t happen again until the next day. I have tried recreating the environment by running the goodnight routine and then triggering the light and it’s only happened once. There is no competing routing that would set it at a different percentage. To reduce complexity I removed the dimming function to just be On/Off but it’s still having the same issue.
You need to figure out if the hub is sending commands to the switch or if the hub is reacting to commands received from the switch. I would use the ST CLI to do driver logging. Also, are you using the stock driver or a community developed driver?
stock driver. will mess around with the cli to see if I can get some debugging logs
Download the CLI to a Linux/Windows/macOS computer and use the command “smartthings edge:drivers:logcat” and select the driver to log. You can also use the “-a” command line option to log all drivers (very verbose though).
You might also try the community developed driver from @csstup that combined all the GE/Jasco work from @philh30. Subscribe to his channel here and install the zwave-switch CS driver.
Same issue, random dimming. Typically don’t notice since it just randomly dims to 96%. GE z-wave on v3 ST.
Yesterday I removed I removed the device from all routines and unpaired it from SmartThings. I re-added the device back to smartthings and to the routines as if it was starting clean. It went crazy this morning. Could it be hardware failure?
2024-12-28T13:34:22.395545355Z TRACE Z-Wave Switch CS  Z-Wave command(4ee95455) queued for radio transmission: CC:Basic, CID:0x01
2024-12-28T13:34:22.405128189Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:34:22.409590314Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:34:22.538686647Z TRACE Z-Wave Switch CS  Z-Wave command(4ee95455) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:34:27.415395685Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2024-12-28T13:34:27.421204546Z TRACE Z-Wave Switch CS  Z-Wave command(74fa3a98) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2024-12-28T13:34:27.435627879Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:34:36.869547691Z TRACE Z-Wave Switch CS  Z-Wave command(74fa3a98) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:34:36.885694386Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:34:36.886820490Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value="OFF_DISABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2024-12-28T13:34:36.902792680Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch
2024-12-28T13:34:36.903962015Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2024-12-28T13:34:36.925314936Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch
2024-12-28T13:34:36.926485771Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch
2024-12-28T13:34:36.927804930Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:37:40.873344396Z TRACE Z-Wave Switch CS  Received event with handler capability
2024-12-28T13:37:40.886440313Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received command: {"args":{},"capability":"switch","command":"on","component":"main","positional_args":{}}
2024-12-28T13:37:40.894786146Z TRACE Z-Wave Switch CS  Found CapabilityCommandDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:37:40.895974729Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> sending Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\xFF", src_channel=0, version=1}
2024-12-28T13:37:40.902965979Z TRACE Z-Wave Switch CS  Z-Wave command(a2f9dc29) queued for radio transmission: CC:Basic, CID:0x01
2024-12-28T13:37:40.911559604Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:37:40.916571521Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:37:41.038695646Z TRACE Z-Wave Switch CS  Z-Wave command(a2f9dc29) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:37:45.925409188Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2024-12-28T13:37:45.931969855Z TRACE Z-Wave Switch CS  Z-Wave command(f80181c8) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2024-12-28T13:37:45.945146855Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:37:46.038679855Z TRACE Z-Wave Switch CS  Z-Wave command(f80181c8) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:38:24.614673526Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:38:24.616070985Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=4}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x04", src_channel=0, version=1}
2024-12-28T13:38:24.667525235Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:38:24.683254860Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:38:24.742651526Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":4}}
2024-12-28T13:38:24.834438651Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:38:36.105790452Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:38:36.106949823Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=1}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x01", src_channel=0, version=1}
2024-12-28T13:38:36.119119863Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:38:36.123390539Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:38:36.139138534Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":1}}
2024-12-28T13:38:36.165783017Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:38:46.535327133Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:38:46.536719842Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=2}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x02", src_channel=0, version=1}
2024-12-28T13:38:46.549187425Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:38:46.553400008Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:38:46.568970258Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":2}}
2024-12-28T13:38:46.589164300Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:40:11.495333602Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:40:11.496740102Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=87}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="W", src_channel=0, version=1}
2024-12-28T13:40:11.509105893Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:40:11.513292185Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:40:11.528943518Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":87}}
2024-12-28T13:40:11.548494602Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:40:21.895790603Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:40:21.897169853Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=83}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="S", src_channel=0, version=1}
2024-12-28T13:40:21.909237811Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:40:21.913422103Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:40:21.929149520Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":83}}
2024-12-28T13:40:21.955848770Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:40:32.295686521Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:40:32.297090646Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=43}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="+", src_channel=0, version=1}
2024-12-28T13:40:32.309412563Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:40:32.313603146Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:40:32.330399313Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":43}}
2024-12-28T13:40:32.349758313Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:40:42.771188605Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:40:42.775662855Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=90}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="Z", src_channel=0, version=1}
2024-12-28T13:40:42.791455897Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:40:42.795829730Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:40:42.883268022Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":90}}
2024-12-28T13:40:43.075289564Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:40:53.185987440Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:40:53.211288857Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=87}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="W", src_channel=0, version=1}
2024-12-28T13:40:53.325244815Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:40:53.354631315Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:40:53.429057940Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":87}}
2024-12-28T13:40:53.681413732Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:41:03.733818400Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:41:03.771533191Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=88}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="X", src_channel=0, version=1}
2024-12-28T13:41:03.851333191Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:41:04.010000191Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:41:04.095097025Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":88}}
2024-12-28T13:41:04.178469650Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:41:24.444527485Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:41:24.513563360Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=84}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="T", src_channel=0, version=1}
2024-12-28T13:41:24.580577527Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:41:24.605221652Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:41:24.674021735Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":84}}
2024-12-28T13:41:24.738026652Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:41:46.395472071Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:41:46.396858030Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=82}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="R", src_channel=0, version=1}
2024-12-28T13:41:46.409154030Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:41:46.414817738Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:41:46.430412988Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":82}}
2024-12-28T13:41:46.450342405Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:41:56.795377323Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:41:56.796761364Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=99}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="c", src_channel=0, version=1}
2024-12-28T13:41:56.809042239Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:41:56.813388448Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:41:56.828952156Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":100}}
2024-12-28T13:41:56.849130448Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:42:07.195253116Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:42:07.196839449Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=80}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="P", src_channel=0, version=1}
2024-12-28T13:42:07.209876407Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:42:07.214068199Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:42:07.229568616Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":80}}
2024-12-28T13:42:07.248853116Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:42:17.596342992Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:42:17.597732367Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=99}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="c", src_channel=0, version=1}
2024-12-28T13:42:17.610036908Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:42:17.614380908Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:42:17.629854825Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":100}}
2024-12-28T13:42:17.649361533Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:43:32.195511198Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:43:32.196673032Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value=99}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="c", src_channel=0, version=1}
2024-12-28T13:43:32.209019407Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:43:32.213229948Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-12-28T13:43:32.229188407Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":100}}
2024-12-28T13:43:32.241332948Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:45:49.774771673Z TRACE Z-Wave Switch CS  Received event with handler capability
2024-12-28T13:45:49.785170215Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received command: {"args":{},"capability":"switch","command":"off","component":"main","positional_args":{}}
2024-12-28T13:45:49.790085006Z TRACE Z-Wave Switch CS  Found CapabilityCommandDispatcher handler in zwave-switch -> ge zwave
2024-12-28T13:45:49.796191131Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> sending Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x00", src_channel=0, version=1}
2024-12-28T13:45:49.817370548Z TRACE Z-Wave Switch CS  Z-Wave command(e0061bca) queued for radio transmission: CC:Basic, CID:0x01
2024-12-28T13:45:49.826020090Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:45:49.830707131Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:45:49.908623215Z TRACE Z-Wave Switch CS  Z-Wave command(e0061bca) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:45:54.830913632Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2024-12-28T13:45:54.837746882Z TRACE Z-Wave Switch CS  Z-Wave command(cf292281) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2024-12-28T13:45:54.844578132Z DEBUG Z-Wave Switch CS  GE Dimmer 12724 device thread event handled
2024-12-28T13:45:54.939371590Z TRACE Z-Wave Switch CS  Z-Wave command(cf292281) transmit status: TRANSMIT_COMPLETE_OK
2024-12-28T13:45:54.955687799Z TRACE Z-Wave Switch CS  Received event with handler unnamed
2024-12-28T13:45:54.956824090Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> received Z-Wave command: {args={value="OFF_DISABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2024-12-28T13:45:54.971790757Z TRACE Z-Wave Switch CS  Found ZwaveDispatcher handler in zwave-switch
2024-12-28T13:45:54.972966882Z INFO Z-Wave Switch CS  <ZwaveDevice: e3dd2e30-b5af-4d89-9027-73a95e841955 [14] (Kitchen Light Dimmer)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
It’s certainly looking that way. I see the On command sent to the switch and then the Report back that the switch is on and at what level. But then, a flurry of unsolicited commands are received from the switch showing different levels being set.
If this switch has an air gap, I’d pull it out to cut power to it. If not, I’d flip the breaker to cut power. If that doesn’t fix it and the device is less than 5 years old, I’d contact Jasco support for a warranty replacement.
Replaced the switch with a new one and symptoms have gone away. Chalk it up to faulty hardware.
