These two keeps going offline all the time, i know it is not a distance problem.
unplugg and plugg and they are online again.
I have one gardenspot RGBW that is stable online, so it is not a all lightify problem.
Anyone else exprience this?
I’ve got a Gardenspot white - but I don’t believe that they’re temperature bulbs, so this could be the issue you’re having.
I use the “Improved Zigbee Hue Bulb MA” DH for mine and it’s solid as anything.
Found it, applied it.
Will test it once I get home.
Thx a bunc.
I was having the same issue with the RGB version. One would not stay connected - the other one which was right next to it had no problem.
I ended up having to swap out the controller.
However I’m having several zigbee devices with the same behavior.
Swap Lightify controller?
My 3 lightify things is direct connect to ST.
My RGB is stable as rock.
No, sorry I meant swap the zigbee controller.
thx for clarifying.
A lot of words and things to keep track on
