Following up:
It looks like the Gardenspots are a bit sensitive about getting too much data all at once - if I try to send a level
command as well as a switch
command (as per the original DTH) they get all grumpy and stop responding to switch commands until they’re power cycled.
I’ve got them working with the following DTH:
* Osram Lightify Bulb (Color Temp Adjustable)
* Copyright 2014 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Modified by jymbob from DTH by Sticks18
metadata {
definition (name: "Lightify Gardenspot W", namespace: "jymbob", author: "James Scholes") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Switch"
capability "Switch Level"
capability "Light"
fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,FC04,FC0F", outClusters: "0019"
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "off", label: '${name}', action: "switch.on", icon: "st.switches.light.off", backgroundColor: "#ffffff"
state "on", label: '${name}', action: "switch.off", icon: "st.switches.light.on", backgroundColor: "#79b821"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 2, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
valueTile("level", "device.level", inactiveLabel: false, decoration: "flat") {
state "level", label: 'Level ${currentValue}%'
main(["switch"])
details(["switch", "refresh", "levelSliderControl", "level"])
// Parse incoming device messages to generate events
log.trace description
def msg = zigbee.parse(description)
if (description?.startsWith("catchall:")) {
log.trace msg
log.trace "data: $msg.data"
if(description?.endsWith("0100") ||description?.endsWith("1001"))
def result = createEvent(name: "switch", value: "on")
log.debug "Parse returned ${result?.descriptionText}"
return result
if(description?.endsWith("0000") || description?.endsWith("1000"))
def result = createEvent(name: "switch", value: "off")
return result
if (description?.startsWith("read attr")) {
Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
log.debug "Desc Map: $descMap"
switch (descMap.cluster) {
case "0008":
log.debug description[-2..-1]
def i = Math.round(convertHexToInt(descMap.value) / 256 * 100 )
sendEvent( name: "level", value: i )
sendEvent( name: "switch.setLevel", value: i) //added to help subscribers
break
case "0300":
log.debug descMap.value
def i = Math.round( 1000000 / convertHexToInt(descMap.value))
def j = i
break
def on() {
log.debug "on()"
sendEvent(name: "switch", value: "on")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}"
def off() {
log.debug "off()"
sendEvent(name: "switch", value: "off")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}"
def refresh() {
"st rattr 0x${device.deviceNetworkId} ${endpointId} 6 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} ${endpointId} 8 0", "delay 500",
def setLevel(value) {
log.trace "setLevel($value)"
def cmds = []
if (value == 0) {
cmds << "st cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}"
else if (device.latestValue("switch") == "off") {
//uncomment to switch on when level is not 0
//sendEvent(name: "switch", value: "on")
sendEvent(name: "level", value: value)
def level = hex(value * 255 / 100)
cmds << "st cmd 0x${device.deviceNetworkId} ${endpointId} 8 4 {${level} 1500}"
//log.debug cmds
cmds
def updated() {
"st wattr 0x${device.deviceNetworkId} ${endpointId} 8 0x10 0x21 {0015}", "delay 500",
"st wattr 0x${device.deviceNetworkId} ${endpointId} 8 0x11 0x20 {fe}"
def configure() {
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Confuguring Reporting and Bindings."
def configCmds = [
//Switch Reporting
"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
"send 0x${device.deviceNetworkId} ${endpointId} 1", "delay 1000",
//Level Control Reporting
"zcl global send-me-a-report 8 0 0x20 5 3600 {0010}", "delay 200",
"send 0x${device.deviceNetworkId} ${endpointId} 1", "delay 1500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 6 {${device.zigbeeId}} {}", "delay 1000",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 8 {${device.zigbeeId}} {}", "delay 1000",
return configCmds + refresh() // send refresh cmds as part of config
def uninstalled() {
log.debug "uninstalled()"
response("zcl rftd")
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = "0" + s
s
private hexSixteen(value, width=4) {
s = "0" + s
s
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
Hope somebody finds that helpful.
(NB: What’s the best way to embed a block of code? code
tags didn’t render right so I went with pre
, rather than manually indenting it all by four spaces)
Edit: code block works if I use the ` character three times at the start and end
