I’m U.K. based and I’m heavily into the SmartThings and lightwave tech.
I’ve got all of my lightwave devices within SmartThings except the single L82 relay I own. Obviously that appears within the lightwave app and is controllable.
Is there something I’m missing? Is this device not supported yet?
A google and a search of this forum hasn’t shown anything obvious up.
Hi @andysmith13. Sorry it’s taken me a while to reply.
The fix was the following. Within the lightwave app, create a “dummy” gen1 socket. Which you do by going to “add”, then “link connect series”, “power” and “socket”.
Once that’s made you use a lightwave automation to mirror that dummy socket to the relay.
The dummy socket shows up in smartthings and will therefore control the relay from there.
Hi Dave
I’m also a big lightwave user, I even modify the door contacts to work on my PIRs so I have garden detection, this can then switch different lights on and off in the house as well as the floodlights, then along comes ST , now I have lightwaverf and ST linked, but I would like to know if I can use the temperature sensor built into most ST units to turn on my heating, I can not see lightwave thermostat in the ST app , is this possible? Many thanks Darren
Update.
Thinking on what you put, I created a socket (fake one) and made an routine in lightwaverf, then used that socket in ST , which likes like it may work, open my eyes up, so thanks for the post
Hi Dave
No that info you give above is just what I needed, I made a socket on lightwave called “not real” and set an automation to set “when on” to turn the thermostat to 22 degs and then the TRV to 22 degs , then the “not real” appears in the ST app, I then set a rule when motion is sense/temp/time is meet it turns on the “not real” socket, bingo , if no motion heating off all thanks to you
