I have had a SmartThings set up at home for about a month and half now. And, I’m trying to find a light-switch/dimmer that I am happy with.
I initially started with the GE dimmer switchers. I like how these look and generally like the push top for on, push bottom for off like a non-zwave decora switch. The thing that irritates me about the switch is the delay in having the switch come on. Pushing the switch to light coming on takes upwards of 2 seconds. I would really like instant on.
I recently bought a Leviton VRMX1-1LZ. Much better instant ON time for this switch. The downsides for me are:
I don’t like the single-button toggle behavior. You push only the bottom to turn on/off the switch.
Doesn’t seem like I can configure the LED on the bottom of the switch to be on or off.
The dimmer bar is ridiculously thin, and I find it hard to press.
Lastly, the switch is so deep, I had trouble getting it into the box with the wiring behind it.
Still so far it is the best choice I have.
I was looking at the Cooper Aspire RF (RF9540-NAW) switches, but am hesitant since it appears that there is a single ramp rate for both up and down. I think a nice ramp down to off on the dimmer is appealing, but I want the light to instant on. Or at least I’d like to be able to set up so it will instant-on. Since the Cooper seems to only have one ramp-rate, it looks like either it is instant on and off or ramped on and off. Is it?
Has anyone found any other switches that they like? Is the GE zigbee switch any faster? Or is it the same as the Z wave switch?
I will give this a try, but I am dubious it will help. I’m talking about physically activating the switch is slow. I press the physical switch to turn on the light, it comes on with no discernible ramp up, but the lamp doesn’t come on for up to two seconds.
What kind of bulbs are you using with the dimmer, and are you sure they’re dimmable? My GE dimmers are nowhere near that slow with supported bulbs, but I’ve seen that behavior with non-dimmable bulbs.
So, it does look like changing the ramp time and/or step size does in-fact make the light come on much faster. Unfortunately, it changes the ramp-down time as well. And it make it very hard to set the dim level from the switch.
