Life after the IDE: Questions and Answers
Question: How do I delete or rename a device now?
Answer: you can do this at the new web interface. Tap on the device tile, then choose the little gear icon to edit it.
https://my.smartthings.com
There is certainly hub information out there in the API if you know where to look. My feeling is that what there is might be either replaced, or augmented, by something more user friendly.
            "zigbeeAvailability": "Available",
            "zigbeeChannel": "13",
            "zigbeeEui": "D043C6786DFA5774",
            "zigbeeFirmware": "5.4.4",
            "zigbeeNcpFirmware": "5.1.2",
            "zigbeeNodeID": "0000",
            "zigbeeOta": "0",
            "zigbeePanID": "9B45",
            "zigbeePowerLevel": "-14",
            "zigbeeRadioDetected": "true",
            "zigbeeRadioEnabled": "true",
            "zigbeeRadioFunctional": "true",
            "zigbeeRequiresExternalHardware": "false",
            "zigbeeType": "15",
            "zigbeeUnsecureRejoin": "true",
            "zwaveAvailability": "Available",
            "zwaveControllerStatus": "1C",
            "zwaveHomeID": "D143C8C9",
            "zwaveLibraryType": "CONTROLLER_BRIDGE",
            "zwaveNodeID": "01",
            "zwavePowerLevel": "full",
            "zwaveRadioDetected": "true",
            "zwaveRadioEnabled": "true",
            "zwaveRadioFunctional": "true",
            "zwaveRegion": "EU",
            "zwaveRequiresExternalHardware": "false",
            "zwaveSerialVersion": "0",
            "zwaveStaticDsk": "98415-56884-23456-87643-98765-66448-98876-00879",
            "zwaveSucID": "01",
            "zwaveVersion": "6.04",
            "zwaveZipGatewayVersion": "0.9.1"
If only this stuff was placed in an informational area in the app. Like, I don’t know, the “Information” menu on the hub details perhaps.
Isnt there supposed to be a new app released in the one day… lets hope when one day arrives all the missing pieces re appear
Question: how do you get the manufacturer and model information without the IDE?
Answer: there are actually a few different methods.
a) You can temporarily assign the device to one of the utility drivers that displays it, then assign it back to the regular driver. Mariano’s zwave thing for zwave devices or Zigbee thing for Zigbee devices will both do this. You should be able to find both in his channel which is linked at the end of the first post in the following thread.
(New Release) New Edge Driver Z-Wave Device Config Mc
b) You can query the CLI.
c) You can use a community-created web-based utility like API +
SmartThings API Browser+ ... Now Available to All
None of these are as easy as the old IDE, but it should be doable.
See the following discussion thread for details:
How to Get the Manufacturer ID and Model (fingerprint) without the IDE?
Question: how do you change the Zigbee channel on the hub once the IDE is gone?
And will there be a way to change the Thread channel? (Mesh commissioning)
edited to update: SmartThings has delivered Thread support by using the same radio they use for Zigbee. This has pluses and minuses, but a major note is that zigbee and thread will always have to be on the same channel in an ST setup because of the shared radio.
So I suspect, but do not know, that we will no longer have the option to force a channel change.
d) The API - You can do this with Post Man, which is probably the easiest. I occasionally do it just with cURL
curl --location --request GET ‘https://api.smartthings.com/v1/devices/my_device_ID_I_Want_To_See’ --header ‘Authorization: Bearer My_SmartThings_Token_ID’
Output:
"deviceId": "device ID",
    "name": "basic-switch",
    "label": "Zigbee Switch",
    "manufacturerName": "SmartThingsCommunity",
    "presentationId": "secret",
    "deviceManufacturerCode": "_TZ3000_f97vq5mn",
    "locationId": "secret",
    "components": [
            "id": "main",
            "label": "main",
            "capabilities": [
                    "id": "switch",
                    "version": 1
                    "id": "firmwareUpdate",
                    "version": 1
                    "id": "refresh",
                    "version": 1
            "categories": [
                    "name": "Switch",
                    "categoryType": "manufacturer"
    "createTime": "2022-12-03T18:29:44.250Z",
    "parentDeviceId": "secret",
    "profile": {
        "id": "secret"
    "zigbee": {
        "eui": "2C1165FFFE99BCE3",
        "networkId": "E2C4",
        "driverId": "f2e891c6-00cc-446c-9192-8ebda63d9898",
        "executingLocally": true,
        "hubId": "secret",
        "provisioningState": "PROVISIONED"
    "type": "ZIGBEE",
    "restrictionTier": 0,
    "allowed": null
Has anyone here managed to get the EDGE devices to show up in Home Assistant? They work fine with DH but they don’t get added if they use edge drivers, what gives?
Just in time (I read it won’t be possible after today), yesterday I used the IDE to change my hub zigbee channel to 15. I needed to modify as my Eero router does not allow me to modify the wifi channel. In the ST app on an android tablet I noticed today that it has automatically modified my future Thread network channel to 15.
Everything has now been paused, the latest date is 1st quater 23, so no need to panick about 31st
Q: Where to check Zigbee routing?
A: at the time of this posting, it will not be available after IDE is terminated. Whether it will be at some point in the future is unknown.
Question:
How can I see live logging of a device that is using an edge driver?
Answer:
@philh30 , a community developer, has instructions in his github for how to do this kind of live logging. You will need to have a laptop running the CLI (command level interface, a programmer tool for the new architecture).
Question: How do I add a room?
Answer: use my.smartthings.com and select the plus sign in the upper right:
You can also add a room in the “Manage Room” tab which is reachable at the bottom of the room selection dropdown. Simply click on the + sign.
3 posts were split to a new topic: How can I add more than 20 rooms?
QUESTION: How can I reboot the hub remotely without the IDE?
ANSWER: Sadly, there doesn’t seem to be an official way to do this. There’s no option in the app, at my.smartthings.com , and apparently no option through the API. :thinking:
What many people have done over the years is plug the hub into a smart Wi-Fi plug which has its own app Independent of smartthings, like Meross. That way you can use that plug remotely to cut power to the hub and restore it.
There should be even more choices for smart plugs once matter is widely deployed.
(Of course, this option requires that the building have both power and Internet, but that’s true of the old IDE reboot option as well.)
ST Wi-Fi (Plume) hubs have the ability to be rebooted from the ST app. Select hub-> Network Status-> Select hub/sub-hub->3 dot menu-> Reboot device.
Don’t know about the Connect Home hubs.
Making a call to the new API to see IDE pages is easy enough, as is running the command to reboot the hub as the IDE does (it is a POST). Doing the latter with the required authentication is not so easy, and if it is possible then it exceeds my current capabilities and my willingness to push my curiosity further. I would hope there is a ‘new’ approach on the horizon.
Question: how do you run a zwave repair without the IDE?
Answer: it’s available in the smartthings app as an option under the hub.
FAQ: Zwave Repair from the ST app (June 2022)
