I have many LG wireless/ZigBee bulbs and wondering if there is a way to make them compatible with SmartThings hub. Model number is B1027EB0Z02.
Thanks.
It looks like they should work fine as ZHA bulbs, just reset them, pair them to the smartthings hub, and then change the device type handler to zigbee dimmer.
Ok thanks I will try resetting them.
@JDRoberts can you tell me where you found out if it’s compatible please. Thanks.
I was able to re-pair the bulb, and have the on/off function work, but the dimming feature doesn’t appear to work. Is there any update available I can do?
Are you using the SmartThings Classic app or the Samsung Connect app?
I’m using the smart things app. But I’ve logged into account.smartthings.com to make the bulb type changes.
There are two SmartThings apps - Classic has the one big circle for the logo, SmartThings (Samsung Connect) has 6 small circles for the logo. Sounds like you have the Samsung Connect app. It is recommended that you install the SmartThings Classic app and use it at this point. The new Samsung Connect does not have all the functionality that is in the Classic app.
SmartThings with the 5 circles - I guess that’s the connect
You are right, I downloaded the classic, and I CAN DIM MY BULB!
I have read the thread…
- Not getting where is the ZHA bulb option?
- It was added as thing i went to My devices > selected the bulb > Edit > Selected type > Zigbee dimmer
It was added but not able to use ON/OFF function - I am using ST one circle classic app
Please advise where i went worng
I can’t get my Lg smart bulb to go into pairing mode - any ideas? I did the powering on/off 10 times in quick succession several times to no avail.
