Having a problem where my new Leviton DW15S-1BZ Decora Smart Wi-Fi 15A are not showing up on my Smartthings hub to setup. Am I suppose to see something in my wifi network? If so what would that be be?
The switch are powered. I follow the steps of pushing the pad once on the switch with no effect. Smartthings does not discover the switch device…
did you set them up with the Leviton app first?
Your thread title says “zwave,” but that model number is WiFi, not zwave. Please check the model number to make sure which it is.
https://www.leviton.com/en/products/dw15s-1bz
https://www.leviton.com/en/products/dz15s-1bz
If it is Wi-Fi, then the integration is cloud to cloud, so you need to set up the switch with the Leviton app first.
If it is Z wave, you will not use a Leviton app, you will connect it directly to the smartthings hub.
No sir… I will set directly and see what happens… Thanks
Wishing you the best,
Armando O Ortiz
210-364-1660
"Leaders…
Are Like Eagles, They Don’t Flock, You Find Them One At A Time.
I just looked it up at Leviton and it reads:
DZ15S-1BZ
15A Decora Smart with Z-Wave Plus Technology Switch
I tried to connect to Smartthings hub without success. It just true to
Armando O Ortiz
210-364-1660
"Leaders…
Bry
(Bryan)
October 14, 2019, 10:19pm
6
In your first post you said you have a DW15S-1BZ, which is WiFi. https://www.leviton.com/en/products/dw15s-1bz
So perhaps double-check the model number and let us know which is correct.
I tried but the router by spectrum will not allow it to be visible to connect…
