Leviton dzpd3 plug in outlet change indicator LED behavior?
Is there a way to have the green LED indicator light be on when the outlet is on and off when the outlet is off? By default the behavior is the opposite. I have changed most my other switches to this (the GE Fan wall switches are the exception) to this, but I don’t see an option for the Leviton.
Yes, that’s called “locator mode” for that particular model. “Locator mode“ means that the indicator LED is on when the device is off so you can find it in the dark. “Status mode“ means that the LED is on when the device is on and off when the device is off. Or you can set it always be off.
you will need to change parameter seven as described in the following specs:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/322
If the DTH that you are using doesn’t expose these parameters, you can temporarily change the DTH to the “zwave tweaker,“ set the parameters there, and then change back to your regular everyday DTH. The parameter settings are saved in the device so changing DTH doesn’t change them.
If you have any questions about how to use the tweaker, please ask in that thread.
Also note that these instructions are for this specific model only. Leviton reuses the same plastic case for a number of different models, so they will look identical, but have very different features. :smiling_face_with_sunglasses:
Thanks JD. That was easy! Great tool.
Yeah, @zcapr17 does great work. :tada: :sunglasses:
