hotsparks
(James L)
August 25, 2017, 7:20pm
1
Installed Dimmer and the indicator light does not come on at all. I thought I noticed it on right after install but not sure because I was installing three switches in one box. I did remove and reactivate it to ST. I’ve tried both indicator settings. I know this may not be a ST issue but it’s a place to start.
pizzinini
(Pizzinini)
August 25, 2017, 7:27pm
2
is the dimmer switch working correctly? This can happen when the dimm level is near 0 and the lamp looks like its off but it is actually on.
You could use the zwave tweaker app to view the device value for the LED indicator and then try to change it:
z-wave Tweaker
Version: 0.08 (2017-03-16)
Source: https://github.com/codersaur/SmartThings/tree/master/devices/zwave-tweaker
This is a device handler to assist with interrogating and tweaking Z-Wave devices. It’s designed for end-users who want to tweak their devices and for developers who want to quickly discover and report the functionality of new devices. It is intended to temporarily replace a device’s normal device handler.
Key features in v0.08:
Discover association groups, multi-channel endpoints, and configuration parameters.
Configure association group members from the SmartThings GUI.
Configure parameter values from the SmartThings GUI.
Configure Protection and Switch_All modes from the SmartThings GUI.
Discover supported meter/alarm/notification/sensor report types.
Automa…
According to this online documentation :
LED Light
When shipped from the factory, the LED is set to turn ON when the connected light is turned OFF. This is the default setting and can be changed if your primary controller supports the node configuration function. To make the LED turn ON when the light is turned ON, change parameter 3’s value to “1”. To turn the LED OFF at all times, change parameter 3’s value to 2.
Parameter No: 3
Length: 1 Byte
Valid Values = 0, 1 or 2 (default 0)
hotsparks
(James L)
August 25, 2017, 7:57pm
4
The dimmer is working fine. I can view my indicator settings for my device on smartthings IDE. Is the tweaker going to tell me any more?
Is there a way to verify if the light is even working?
hotsparks
(James L)
August 27, 2017, 7:58pm
5
I just changed out the switch. No more problem. LED works as intended. I just bought the bad switch so it will be going back.
