After installing the latest IOS app on my iPhone 13 Pro Max with the latest IOS operating system, it worked properly for a few days. After a few days, I went into edit a device and found that the delete device was missing. I tried removing the app and reinstalled, but problem persists.
You can tap on the 3 dots in a room and select remove device.
Hoover over the device in a room to get the popover with Remove
The Delete/Remove option has been removed when you open a device, tap 3 dots and select Edit.
Thank you, There should have been a note on this.
That’s too easy.
Samsung likes us to work it out by accident.
