Kwikset Deadbolt Range Issues
Just bought a Kwikset Signature Series HomeConnect Deadbolt, which is a z-wave lock.
I have 2 Yale locks on my system which work well. One is about 20 feet from the Hub in my house, the other about 70 feet in a separate building. Both work perfectly.
I paired the Kwikset deadbolt as the manual said, with it less than 1 foot from the hub. Paired fine and lock/unlock work with the hub right next to the lock.
However, once I move the hub back to it’s location, which is about 15 feet from the lock, the lock doesn’t work.
I know the lock is within range as I have a Fibaro Dimmer 2 and a GE Power Outlet both about 2 feet from the lock.
I have tried excluding and re-pairing the lock to make sure it is paired properly, I had to do this again with the hub a foot away.
Still not working once the hub is 15ft from the lock.
Any ideas?
Do a "Repair Z-wave Network, It’s found in the hamburger menu under Hub.
Tried a repair multiple times, says Failure: unable to update route
Nobody else has had these issues with the Kwikset z-wave locks?
Or suggestions on a fix?
Any fixes? Same issue here! Any help much appreciated!
