I just installed the Kwikset 914–seemed to go well and was able to operate normally (ie, lock would open and close on command from my iPhone and properly sense if lock was locked or open–until I manually locked it from inside–then it would not work at all. I did an other “Door Handing” procedure–which worked successfully and all worked correctly again—until I manually locked the door from inside again—and all stopped working.—Is this the way things work or am I missing something in the setup process?
