Konnected Pro and Buzzer
New Installation. Konnected Alarm Pro and SmartThings.
I have routine for the front door: If door open and armed, send message and activate buzzer.
When I test the routine in edit mode, the buzzer sounds.
Once I save the routine and open the door, I get the message, but the buzzer does not sound. SmartThings shows the door opening.
Konnected support looked at the scripts but suggested that I try here.
can you post a screenshot of the Routine(s)?
Not sure that the image is visible… but I uploaded something
Try making “Security Mode” a precondition.
I’m confused. Don’t I already have Security Mode Armed (away) as a precondition in the routine above?
No, it looks like you have it set as a trigger, not a precondition.
that did the trick, thanks
