I really like the concept of Keep Me Cozy II. What I would REALLY like it to do is the following:
Continue to use the thermostat’s schedule when they next timed-trigger occurs.
Use a temp sensor in the baby’s room to:
a)Turn the thermostat up 2 degrees if the temperature drops below 64 degrees
b)Turn the thermostat down 2 degrees if the temperature rises above 74 degrees
I ONLY want it to adjust the temperate from the baby’s room between sundown and sunrise.
I have a Netatmo weather station and a Filtrete 3M-50. I have integrated them both into SmartThings already.
That should be easy enough to do. You’ll need a sensor that measures temperature and a thermostat that is supported by smartThings. Do you have those?
Once those are installed we can search through the user community for existing code that supports your devices and see if we can modify it to support the functions your want. Are you familiare with groovy and the IDE?
question, why not just get a sensor that tells you what your baby’s room temp is in relation to the temp next to your thermostat? If the room is 2 degrees lower than the rest of the house, set your thermostat two degrees higher during the times your baby is sleeping. The Nest for instance has multiple schedules, so you could have one temp during certain hours and another temp when the baby is going to bed.
Yes. I have a Netatmo weather station and a Filtrete 3M-50. I have integrated them both into SmartThings already.
No, I’m not familiar with groovy or IDE.
Answer: I guess that would work. Right now I just keep a constant eye on the temperatures but was hoping to have SmartThings do it automatically so I don’t have to worry about it.
I have a similar situation and am curious if anyone came up with a solution. I have temperature sensors all over the house (either Everspring 814s or ST multi sensor) and would like to adjust the temperature based on different data points. For example, I like it cold when I sleep so if the temperature in the bedroom is greater than (for example) 70 degrees after 10pm then I’d like the AC to come on. Essentially I want to move “control” over the HVAC system to different rooms based on the system mode, time of day, etc.
I’m guessing this will have to be a SmartApp which adjusts the thermostat set points based on data that I specify but don’t want to reinvent the wheel.
