Issues pairing xfinity XHS2-UE Door / Window Sensor with ST
I read a few articles on these forums and it seemed like I would be able to buy the xFinity XHS2-UE sensors off of eBay, reset them, and then connect them up to ST. But, I can’t seem to get ST to pickup the devices. Hoping someone can help?
Important Info:
Steps to reset:
  • Removed Cover + Took Out Battery
  • Waited at least 5 seconds after the step above, then held down the switch for 3+ seconds and popped the battery back in
  • While the green light is still on (first 4 seconds after putting battery back in), I let go of the switch
  • Go to ST and attempt to scan for device, but it never finds it (this is where I’m stuck)
  • I also tried to go the z-wave generic route, but again it doesn’t find it.
the one that works is model number xhs2-se. i vaguely remember something to the effect that you have to let it pair was a thing and then change the device type.
I saw that the UE was basically interchangeable. What do you mean pair as a ‘thing’? (when I scan nothing is found at all - I had expected to see ‘thing’ then go through the steps of changing it to the tyco device etc.)
when a device pairs as a thing it means that there is no device handler assigned to its finger prints (identity) and you have to go into the IDE and assign a device handler
Thanks - I can’t even get ST to find a device / thing when scanning for the sensor even though its clearly in pairing mode (green light flashes repeadtely for about a minute)
not sure the -ue model will pair. try pairing under st door/window and some others.
Sometimes a device won’t show up as being found, but will actually show in the No Room Assigned category.
Pretty sure the UE works, as I recall some previous discussions on the about UE vs SE, and the main difference was one had a larger battery.
Thank you! This was it…
So for anyone else trying to get these to work you need fo navigate to ‘not assigned’ room and then do the factory reset steps AND try to scan for a device (it won’t find one… but once you try and cancel out of it you’ll magically find ‘thing’ listed in the ‘not assigned’ room). Then you can login via the ST webpage to rename it plus change it to ‘tyco door/window sensor’.
Setup ~20 today and they all work great.
That is correct. Here’s the process I used and it worked for +20 of these.
  1. Take out the plastic tab to activate.
  2. Search for a device with the + sign and scan nearby.
  3. The app will time-out.
  4. Go to No room assigned and you’ll find “Thing”.
  5. Log in to IDE and modify to “Tyco …” and put it in the proper room.
    ----- This is where things get “interesting” for if you don’t do these steps below the sensor either never provides event updates or remain continuously in OPEN state with 0% battery.
  6. Open the top cover of the sensor the flip out the battery.
  7. Start the device scanning process in the app. (Process : see above)
  8. Hold the tamper switch for 3 seconds (min) and 5 seconds (max)
  9. After the 3 to 5 sec. wait (step #8) put the battery back (positive on top - facing you) while continuing to hold the tamper switch.
  10. Immediately the green LED flashes, after a brief interval solid green for approx. 4 seconds.
  11. Release the tamper switch.
  12. At this point or in-between you’ll find the app re-listing the sensor again.
  13. Now - its working as envisaged.
    [Steps 8 to 12 must be completed within 100 seconds]
Followed these steps multiple times with the XHS2-UE and couldn’t get it to pair and it shows nothing in event logs or live logs. I’ve got the v2 ST Hub. I even tried a new sensor and pulled the tab (versus the previously functioning sensor that just stopped working).
Any other tricks to getting these things going? After trying two sensors I’m starting to think its the hub and possibly a recent firmware update.
