Hello - New SmartThings user here having just migrated from Wink.
I have 4 Inovelli switches linked to my hub. The two dimmers are working fine but the two non-dimmer switched keep turning themselves off after 2 minutes and 50 seconds, exactly.
I’ve owned these switches for a while and have never had a problem with them. Load has not changed, just a switch from the Wink to the ST hub. The switches were uninstalled from the the Wink hub which is no longer on-line or even plugged in.
Your best shot if Eric will be able to give some hint, but either you set up by mistake an Automation for them, or actually a Quick Control. Or you did turn on some feature what might causing it on the Z-wave side.
To look at the history, as advised above, would give you a hint is it an Automation/Quick Control or just a simple off command. If not that, then Eric should be the person who can help identify the issue.
These are original LZW30 switches I believe that don’t have a config button or LED bar (more an LED pinpoint light). To pair the device I need to press the on button 6 times in 3 seconds, or something like that.
Anyways, I’ve tried the remove and add multiple times. Each time it automatically selects the Z-Wave Switch Secure as the DH which I then change to the LZW30 DH. I’ve tried all sorts of DH’s and they all act the same. Switch turns off after 2 minutes and 50 seconds.
Is there a way to factory reset these older switches?
Oddly enough the dimmers from the same vintage are ok with the newer DH and work fine. Also, the NZW31 DH also reports dimmer level even for non-dimmer switches which is fine. Looks like the same DH for both dimming and non-dimming switches for the GEN 1 devices.
