I recently changed from smartthings classic to the smartthings app, i’m having real issues understanding the new changes.
I think i’ve changed what i need too however i’m struggling with a routine. I have a presence sensor and my girlfriend connects using her phone.
I’m trying to set everything to arm once we both leave the house. Although the presence sensor is on my list of devices i can’t seem to add this to a routine. Meaning the system only arms once my girlfriend leaves the house so it ends up going off when she leaves for work but i’m still at home.
I’m guessing i’m doing something wrong and there’s not a really useful feature missing from the app?
RBoy
2
The new app doesn’t have a routines, are you referring to an Automation?
You should not see a location sensor on the dashboard or in menu > device list unless it is the sensor from your Classic app, a simulated presence sensor or physical device such as a tracker. If you see a device listed using first name + phone, then that would be the presence sensor from your Classic app. The new app uses first/last name + phone.
To enable presence in the app, click on menu > settings (the cog) and enable use location from this phone. They will not appear in your device list but they will show up when you go to create an automation.
Yes, physical presence sensors work and that will show in your device list. But you mentioned she was using the phone as hers and that will not appear in the device list. But you can see it when you go to create an automation in the member location section. Just checking… she is using the new app’s location and not life360? If she is using the new app, you should see it when you go to build an automation. If life360, that is slightly different… it would show in device status section and not member location.
Thats what i’m looking to do however i think i might be missing options - Are you able to tell me how you got to the point where pictured? so i can double check i’ve not missed anything?
Thanks for your help, I’m still unable to find my girlfriends phone. I might need to re-add her as a member, might explain what the issue is. Thanks again.
