Ya this on our side, nothing to fix on our end.
Thank you sir, please keep us posted.
subâd for updates.
Here I thought I had broke it. Canât find a way to keep on top of this unless I make a post here.
Cheers.
I logged into the IDE this morning, and noticed it was running slow like it always used to. I went right to the DTH section and presto, all of my links are restored, seems like ST fixed the issue, can anybody else confirm/.
That is correct, it wasnât working last night, was working this morning.
At last⌠itâs back up for me too
Links all working for me now in IDE; performance back to poor/abysmal
If youâre using a mouse, you can also middle click with the scroll wheel on a link to open in a new tab
We had a deploy that went out late Tuesday that should have fixed the GitHub Integration issues that you guys were experiencing and reporting to support. Let me know if you having any issues outside of the known issues with the GitHub Integration.
Sorry for the delayed update
Hi SmartThings,
Iâm trying several times to enable the Aeon Labs ZW078-A with SmartThings by jpansarasa (Elastic Development), however Iâm unable to Commit Changes. When I checked the SmartThings Status (http://status.smartthings.com/), all seems to be Operational.
Am I missing something? Any help would be very much appreciated.
Thank you.
Best Regards,
David Wee
Itâs happening again, trying to publish something gets me nowhere - I do have an error in the browserâs console for a request to this URL:
https://graph.api.smartthings.com/ide/$%7Bg.createLink(action:%20'commitForm')%7D/30xxx
I obfuscated the actual app id using xxx
The decoded URL is:
https://graph.api.smartthings.com/ide/${g.createLink(action: 'commitForm')}/30xxx
and the response is 404 Not Found
Anyone else seeing the same?
I donât know about the error, but I havenât been able to push from the ide since yesterday
My Apps and Device handlers are appearing straight away when I click on them in the ide.
They appear not in the correct state, can be light blue italic before turning black.
This is exactly the same as around 2 months ago when ST tried to improve the github integration and all my DTH github integration disappeared.
Iâll bet my socks that ST have tried to do this again and that this is causing the problem.
I found the issue, we should have a fix out within 24 hours. Sorry for the inconvenience
Thank you Luke Prompt as always.
The fix has been deployed, let me know if there are any other issues
