Is it possible to get my lg washer and dryer to connect to my smartthings hub? both are wifi connected. model number for washer is wm9000hva dryer is dlex9000v.
Are these the flexwash and flexdry?
I would love to know the answer to this as well. I cannot get mine connected.
Not directly, but you can connect LG SmartThinq apopliances to SmartThings via IFTTT. I have my Washing machine changing all of my colored Osram LEDs and flash them for 10 seconds when a load is finished.
Mine does not appear in the IFTTT channel, I’m in India, and I think the IFTTT channel only supports US & Korea. I registered my waster/dryer model F4J7THP2S with US account using the LG smartthinq app, then registered IFTTT to the same LG/US account but the washer does not appear as a trigger. Anyone did this outside of US/Korea ? - thanks.
I have the LG washer and Dryer and I have the app working fine but when I go into IFTTT both applets cannot see my devices I get “Option unavailable”
I’ve been trying off and on over the last 6 months with no luck adding my LG appliances to IFTTT, Alexa and Google Home.
Randomly the other day I got Google Home to connect to my LG appliances. I’m not sure what I can all do with it. I can ask how much time left and can stop the Dryer. Doesn’t look like I can pause or anything truly helpful. It would be nice to load up the washer and when i get in bed or after my shower ask it to start .
But I still cannot get Alexa or IFTTT to see my LG stuff :’(
How did you get it to work? I can’t get IFTTT to see my Washer or Dryer
This is from LG chat about IFTTT
They told me the same thing over a year ago. I don’t think they are even working on this.
Hello @ivioo. How did you manage to connect google home and the lg washer? I’ve been trying to do that for 3 months with no luck
Nope, I even tried a few days ago . . . still no luck :’(
Good grief! Same issue now on 11/18/2020!
Reviving this old thread with good news — this is now possible! I built a SmartThings Schema Connector for LG ThinQ washers/dryers using LG’s official Connect API (not a workaround, no IFTTT/Google Home routing needed).
How it works: you generate a Personal Access Token from LG directly, link it through the connector, and your washer/dryer show up as real SmartThings devices — live status (running/drying/done/etc.), remaining time, error codes, and on/off control, plus Routine triggers based on machine status.
Install link: SmartThings Channel and Drivers
Requires a native LG account (not Google/Facebook/Amazon login) — happy to help troubleshoot if you run into anything.
Are LG ThinQ refrigerators included in your driver?
Yes! I have a separate Schema Connector for LG ThinQ refrigerators too - fridge/freezer temperature (with decimal precision), Express Mode, Power Save status, door open/closed, and water filter status. Same setup process (LG Personal Access Token) and it also supports Routines.
Amazing! Does it support enabling/disabling sabbath mode?
I sent you a PM
After you ran a few tests in python, we found out that Shabbat Mode in LG ThinQ fridge is read only property and therefore can’t be controlled by LG API. BTW, no problem exist to control Shabbat mode in Samsung Fridges.
Just purchased a LGThinq washer and dryer and trying to connect to my Smart things app as almost everything else in the house is through that app. Any advice?
Well, there used to be an integration between the LG Thinq laundry devices through the LG Thinq app, but I don’t see it in Add Devices anymore. And while mine still shows linked, I get errors trying to control them in ST. Guess it’s been discontinued by LG since they were responsible for the cloud->cloud integration.
You could try the schema connector from @dotan_shai but I’m getting a permission denied from his link. Could be the recent changes in the ST API and supported app types.
