Edited my appropriate device by copying the entire linked code above, replacing the starter code in the field.
Saved it. Published it.It appears in my list of device types.
No effect.
Restarted the iPhone app.
No effect.
Well, there sort of has been an effect. The kitchen sensor stopped working, but I’m unclear about the timing. I’m switching it back now to the “stock” Aeon Motion choice.
I’m about to reboot my ST hub and see if that makes a difference.
In other news, I thought readers would like to know that it appears the Monoprice motion sensors have a wider field of view than the ST Motion sensor. My estimate is that the ST version has about 78° of view, and the Monoprice is more like 89°, making it a great choice for putting in a corner to cover a room.
@DifferentComputers, if it’s showing °F then it sounds like it’s working.
But if you meant to say, “Still °C,” instead and it’s actually still using the Aeon device type, make sure you do the following after creating the device type:
OK, I’m wrong. ONE monoprice sensor reports in F°, but the other, even after changing the device type in the IDE and restarting the iOS app, still reports C°. WTF?
Does rebooting the hub maybe have anything to do with it? Because I’ve rebooted before the latest device redefinition, but not since.
When I updated my sensor’s device type, I didn’t have to reboot the hub. I didn’t have to kill the app, but it might have crashed on its own. Originally I was using the wrong device type that you linked to in your earlier step-by-step post, so the device type was set to the Florian’s Monoprice door/window sensor. But after I grabbed the right code and edited and published the device type, it started working. I might have changed it to the Aeon device type then back to the Monoprice device type, but I don’t remember for sure.
Assuming both sensors are the Monoprice motion sensor w/temp, you could first try setting it back to the Aeon device type, then back to the Monoprice device type. If that doesn’t work, I would try unpairing the misbehaving device. If you have any extraneous device types that don’t work or that you don’t use, delete them. Then pair the sensor again and set it to the already-created custom device type in the IDE.
@urman that’s great! I was wondering if anyone from SmartThings was following the progress here.
Does this mean you’ll be adding Monoprice devices to the compatibility list spreadsheet? It would be nice if the document could be updated at least once a month or so, and if it included devices which are simply rebadged versions of devices that are already on the list.
@urman What’s the status on official compatibility? I just added a motion sensor and it came up as an Aeon still. I looked in the IDE and I didn’t see Monoprice in the list when editing the device - of course, I figured that would be the case since it came up as an Aeon sensor.
Also, the Monoprice door/window sensors came up as generic Zwave sensors. I changed them over to zwave door/window via the IDE. However, it is not really convenient for a novice user to do that. Is there any reason why the different devices can’t be recognized automatically now? Here’s where I see it a problem. When I added the door sensors, the app said that there were no popular actions & alerts available at this time. That is a pretty confusing issue to the general public. I even took screenshots of it thinking it was a bug that I needed to report. Then I came on to the community, searched for Monoprice, read a bunch of threads, and found out what to do. Again, too confusing and complex when it could just be recognized right off the bat as a Monoprice sensor.
As I was packing up to move I got their motion sensor, but haven’t had a chance to dive in yet. We are waiting on their other devices as well. They were on back order for a long time.
If it works as Z-Wave Door/Window then it should be a pretty small fix for us.
@urman I just received two door sensors and a motion. Do you want me to ship you one of the door sensors? I would be happy to help! BTW, they are both VERY chatty in the activity log.
I like @florianz suggestion here. Is it possible to have a single device type that dynamically displays what it needs to display? It does seem like it would simplify matters. Of course, I’m not a coder here, so I don’t know the ramifications of this.
I have a couple Monoprice motions. They used to show temp but they both quit showing the temp a few android smartthings app upgrades ago. Anyone experiencing this?
@mcvoss I have 1 that i’ve had for over a month and two more that I just added this week. They are all working as expected. What device type are you using?
