iPhone Presence Sensor shows only as “connected”
My iPhones connected to Smartthings had been working flawlessly for years to alert me when family members arrive and depart. All the sudden everything just stopped working and they only have a status of “connected”. How do I get them to show home and away again?
Hi @tuffloud1
Here are some steps recommended by the engineering team that might help re-establish the connection:
  1. Open the Advanced Users app
    Go to Devices and find the record of your phone. The type must be “mobile.”
  2. Disable location sharing
    In the SmartThings app, go to Menu > Settings and turn off “Get your location from this phone.”
  3. Check if the device record was deleted
    Go back to the Advanced Users app and verify if the mobile device record was removed.
  • If not, please delete it manually.
  1. Verify location permissions
    On your mobile device, go to:
    Settings > Apps > App Management > SmartThings > Permissions
    and make sure “Location” is set to “Allow all the time.”
  2. Enable location sharing again
    In the SmartThings app, re-enable the option “Get your location from this phone.”
  3. Collect logs
    Right after completing the steps, collect the logs.
    SmartThings → Menu → Contact Us → Error Report → Routine Settings/Operation
    In the details, include the example below and your ticket number (BUG2-4872).
    Note: member presence-related data is only stored for up to 3 days
  4. Note the timestamp
    Write down the exact time you performed the steps. This allows us to pull Cloud logs later if the issue happens again.
For example:
“Returned home at 5 PM – ‘BlaBlaBla’ automation should have triggered but didn’t.”
Why this is important:
This process creates a fresh “link” between the SmartThings app and your phone’s location data.
According to the engineering team, the app itself is what determines the “present”/“not present” state, so it might not be getting accurate location data unless re-synced.
