Creating an issue thread to track reported issue with iOS 2.2.0 and 2.2.1
One reported by @dworkman multiAttributeTiles and valueTiles don’t render the same way on iOS on the list of Things page (e.g. Thermostat temperature)
See screenshot below for issue that @RBoy mentioned. The Upstairs Thermostat is using his custom device handler which uses multiAttributeTiles; the other two thermostats are using the standard SmartThings device handler which apparently use valueTiles.
@Jim could you pass this onto the appropriate team or have them monitor this page
