Hi. I’ve installed a NV7B42205AK Samsung Dual oven and successfully connected it to the SmartThings app on my mobile phone. I’ve also installed the SmartThings skill in Alexa.
I can operate the oven through the SmartThings app.
My wife has a tremor, so I’d like to create some ‘presets’ such as ‘Plate warming’ that starts one of the ovens at a predetermined temperature. Ideally, I’d like to execute the preset via an Alexa voice command (either directly or via an http call) but a button in the SmartThings app would be second best.
So far I’ve tried a manually run routine and Alexa commands without success.
I create a new routine, choose ‘Manually run’ for ‘If’, tap ‘Add what this routine will do’, tap ‘control devices’ only to see ‘No devices found’ in the ‘Select devices’ page. I’ve tried putting various things in the search box: “Oven” (the name of my oven), “Flex upper oven” (the name of one of the two components), “upper”, “lower”, “main” - all give ‘No devices found’.
FWIW, when trying to add an ‘If’ condition, I see ‘Device status’ is greyed out.
Does that mean I can’t use my oven in a routine? Did I miss a step?
The SmartThings app gives several suggestions for Alexa commands. The only one that does anything is “Set oven to xxx” but all it does is switch the oven’s light on! I’ve tried “Set oven to upper”, “Set oven to lower” and “Set oven to main” but they all do the same thing. It doesn’t matter whether I have the upper or lower oven selected, the selection doesn’t change.
However, it proves that Alexa is connecting OK.
Other commands start out promising so, if I say “Set oven temperature” Alexa asks me for a temperature but, when I reply, says “Hmm. I’m not quite sure what went wrong”.
All commands end up with “Hmm. I’m not quite sure what went wrong”.
I’ve tried messing around with the remote setting but I get the same result however it’s set. The WiFi light is solid.
Again, does that mean I can’t use my oven with Alexa? Have I missed something.
Can you help? I’m a retired developer familiar with web stuff and I’ve quite a bit of experience with home automation using various platforms, but this is my first foray into SmartThings,
Andy
