Im considering to add support for the Floalt LED light panel to my IKEA-Tradfri device handler as i’m assuming they behave the same way as the bulbs. I don’t want to buy them in order to get the data i need so if anyone here has them and has connected them with SmartThings i would appreciate if you could give me some info about the device from https://graph.api.smartthings.com/ (remember to select your hub first)
What i need is under “My devices” and the parts are under the “Data” section and the “Raw Description” section.
I was thinking about getting one just for testing it. Might just do it and I’ll help where ever I can. Would be nice to have the Hockey Puck fully working as well.
I don’t have a puck so i haven’t tested it but check this, i don’t think it’s completely finished but i would guess that he would appreciate testing and feedback
Hi Edvald,
I have FLOALT 30x30 and 30x90 panels I would be very interested in adding to my SmartThings. I’ve successfully paired them with my hub, but am unable to control them properly.
model: FLOALT panel WS 30x30
application: 11
manufacturer: IKEA of Sweden
endpointId: 01
Yes, it does work just fine. Took me some time to get the FLOALT paired, but works just like any other TRADRI bulb with your DTH. Thanks for the great work!
If you don’t mind i would really appreciate if you could post the ZigBee fingerprint for the panel, that way the dth will be automatically selected if you have it installed and add a new panel like @silvercat did
I hadn’t added it yet, was waiting for more fingerprints to figure out the pattern but i realised that float has the same as trådfri, just different names so i added all the ones i found at IKEAs site and just changed the name, if anyone has any of the other sizes i would appreciate if you could install the DTH before adding the panel to smartthings, if it doesn’t automatically select the Trådfri handler then let me know
