fester
(Stephen)
April 17, 2017, 2:24pm
1
Hi Everyone,
Has anyone gotten the large 60x60 FLOALT LED panel working with a smart things hub?
I see on this forum several suggestions pressing the on/off button with the remote 7 or more times to go into discovery mode however I am unable to get this to work… including a hard plug/unplug and link pairing using the remote
Would anyone have any other suggestions?
Many Thanks in advance!
Have you put smartthings in discovery mode? I assume so…
fester
(Stephen)
April 17, 2017, 4:25pm
3
HI Sergio,
Thanks for the suggestion… Yes i have…
Event logs on the webportal show “include search” from zwStatus… Does anyone know what Zigbee shows when in discovery mode… im guessing zw is zwave.
Stephen
fester
(Stephen)
April 22, 2017, 6:28pm
4
OK solved the issue…
You need to power off/on 6 times from the electric switch (not the hockey puck) to get it to show in the smartthings discovery
The more you know!
Julius
(Julius Bech)
May 15, 2017, 10:08pm
5
Have you tried pairing the IKEA Remote with the smartthings hub? If yes, how did you do it?
fester
(Stephen)
May 18, 2017, 1:58pm
6
Hey Julius, Unfortunately I haven’t gotten this to work yet however I am keeping a keen eye on IKEA Tradfri Button -- help needed
Julius
(Julius Bech)
May 18, 2017, 2:57pm
7
I found this solving the problem of using the IKEA Remote with the IKEA bulbs while the IKEA bulbs are also connected with the Smartthings Hub:
Adding IKEA Trådfri to SmartThings
Here are step by step instructions for adding an IKEA Trådfri bulb to SmartThings for the first time. Thanks to EDVALD EYSTEINSSON and others, we now have a wonderful device handler that allows better color temperature control over IKEA Trådfri bulbs than the Ikea Gateway or Steering Remote currently allows.
Once the bulb(s) are added to the SmartThings hub, you can also use up to two IKEA Trådfri devices to control one or more bulbs and still maintain control by the SmartThings Hub. Those instructions follow.
Adding IKEA Trådfri bulb device handler to SmartThings
Sign-in to the SmartThings developer API at https://graph.api.smartthings.com/
Choose My Device Handlers at that top, then click the green Create New Device Handler button on the right
Sel…
I still haven’t figured out how to use the IKEA remote with other Smartthings devices, since i can’t find a device handler for the IKEA remote.
fester
(Stephen)
May 18, 2017, 3:41pm
8
Great find!! thank you… I didn’t know you could use the two at the same time… Will give it a try later when I get home
