Ifttt not finding smartthings hub
I haven’t found an exact topic for my specific issue, but when I got to connect ifttt to my smartthings hub and click from drop down My hub is not an option to pick and can’t authorize.
Anyone else had this issue or have a fix?
Thanks in advance.
You are authorizing your hub when you pick your “location.” The hub itself does not appear in the drop-down of devices, just your switches and sensors will appear there.
So I’m not sure if that’s your question or not, but I would just continue on and see if you can authorize any of your other SmartThings-controlled devices. If so, you’re fine. If not, contact support.
Maybe I’ll contact support then. I have several light switches set up your SmartThings and is not finding them. Very possible I’m overlooking something though as I am fairly new to all of this.
Thank you
