IFTTT I need more options
I was using another smart home controller hub and they allow multiple rules listed as WHEN, IF - ELSE, and THEN. I was able to use a door sensor to turn on a outlet and a light, it timed for 7 minutes then turn off automatically. Use a motion sensor to control the same outlet and a different motion sensor to control the light and shut off 5 minutes after motion stopped. Is it possible to do the same with ST or use another platform that works with ST to achieve the same affect. I need more control of my ST. Please help.
You can have all that and more. :sunglasses: Smartthings is very powerful, it’s just not very intuitive.
The following FAQ should be of help (this is a clickable link)
Thank you. Something new to learn but willing. I am a nube and wanting to learn as much as possible and possibly help others once I have learned enough to do so. Again thanks.
You might also find the technical welcome FAQ of interest. It’s in the community – created wiki. :sunglasses:
http://thingsthataresmart.wiki/index.php?title=Welcome_FAQ
It’s mentioned in @JDRoberts’ FAQ . . .
Take a look at webCore.
Tried to install webCoRE and missed the check publish part and cant find it on ST as it showed I should Need help to fix this issue please
Webcore has their own forum (Linked to in the post above). Ask there and you’ll find lots of people to help you. :sunglasses:
Someone mentioned how by clicking on each item from smartthings IDE and posting from that screen. Was vague but figured it out. Unable to access WebCoRE community until trusted. I’m a nube to this. Thank you for the help.
Tagging @anon36505037
pmbrabbs I am using this for the St and wc account. Thank you.
