Was trying to setup an automation within the classic ST app where if my ring doorbell had motion between a set of times (e.g. 7pm to 4am), then to turn on a switch (e.g. Reality Switch in this case). Then after X number of time, turn switch off.
Thinking IFTTT would do in a way, but also think that since automation within ST seem to have a deeper setup if needed, that this should be able to happen within ST app itself. Is this not the case?
Is there anything different you all have done or seen or any other app you have used for these types of things?
