I am trying to use IDE but I cannot find add in the My Device Handlers
Dears
How can I fix this?
Adding custom DTH drivers has been disabled as part of the transition to the new architecture based on Edge drivers. What are you trying to accomplish?
I am trying to add govee and aqara cube (xiaomi cube)
Is there any work around to add govee lights and aqara cube to smartthings??
There is a community edge driver for the Cube here:
I run it with the Aqara and it works well. Plenty of guidance on installing edge drivers can be found elsewhere in the forum (don’t have links to hand) :+1:
Start by reading through the link below, JD explains everything and will show you how to install Edge drivers. Then use the link in the post above to the Aqara driver.
