Is there any way use SmartThings to communicate with the remote controlled RF blinds I have installed in my house? I’ve been researching but I haven’t found anything so far. Any help would be appreciated! Thanks. I also have a harmony hub if that helps at all.
Best thing to do is pickup a Harmony Hub and then you can have the two technologies talk to each other.
I have a harmony hub but it only can do IR commands. Are there any that can do RF?
Hub accepts RF, check out the article:
https://support.myharmony.com/en-us/properly-pointing-the-remote-or-positioning-the-hub
It says that some devices are communicating with RF to the hub but the hub sends IR out. Also I tried and it won’t accept the command from the RF remote. Unless I am missing something major, this is not supported with the hub on its own.
