Hue plugs no longer showing in smartthing
Since the last update I can no longer add hue wall plugs to smartthings I have tried to add my hue stuff both ways possible, everything else will appear apart from my plugs has anyone else had the same issue or know if a fix?
Which update are you referring to… app update or hub firmware update? Which hub do you have? Firmware version of your hub?
My driver referenced above supports plugs, but be aware that there is a ST bug preventing child devices from being created. This bug would apply to the ST version of the driver as well. They are working on a fix to their cloud.
Same problem here. Have u found a fix?
