I have a Samsung ET-WV525 and recently moved to a different location. Now the device will only connect as a wifi device and the hub function will not configure as a hub.
Now I can not connect the z-wave device without the hub function.
Hi, @TedW
Do you mean before moving out, the hub worked correctly as a hub but then you deleted it from the account, then onboarded it again and now you can’t enable this feature?
We’ve seen reports of this before, but we haven’t received any feedback from the team that handles these hubs. So, we suggest you report this problem to Customer Support since:
There are no Customer Support agents in this forum
They can escalate the issue through a different tool that gets to the corresponding team’s backlog
We need to provide more awareness about this issue happening to other users
You can do this from the SmartThings app:
Open the SmartThings app
Go to the menu tab at the bottom-right corner.
On this page, select the option “contact us” and then go to “Error reports”
Select the topic related to your issue and follow the steps to submit your support request
I have a SmartThings WiFi router (model ET-WV525). After a factory reset, it works fine as a Plume mesh router and the ‘SmartThings Wifi-Adaptive’ service is online. However, the integrated hub will not activate and does not appear in the Hubs section of the SmartThings Advanced Web App. This indicates it is failing to register with the SmartThings cloud. Can anyone confirm if hub activation for this model is no longer supported?
I opened a tech support ticket with Samsung Smarthing and here is their response. Guess the hub feature was eliminated from support on the model ET-WV525. so if the feature is work dont change or you will never get it back.
We received the response of Tier 2 team regarding the escalation ticket we submitted. Please check their response in verbatim below:
"The only step for this will be to factory reset the hub and leave it connected until the LED blinks red/green before adding back.
This is a discontinued model, so there are no further steps for this issue. If the issue continues, the user will need to replace the hub having the problem."
