This is a small release fixing a few bugs found in the 0.22.13 release. It will be going to a small number of users who are the most affected on Friday, July 20. We will roll the release out to everyone else at a later date (targeting July 26). The changes are as follows:
Fix hub reboots caused by local SmartAlert Sirens
Fix Zigbee Siren reporting incorrect state (off when on and vice versa)
Just wonder , will be ever fixed the Skybell integration - SkyBell detects motion but Smartthings does nothing. SkyBell support blames ST firmware update broke the integration, and a fix must be completed on ST side, they communicated the fix code 6 months ago, no results.
Same issue here with the harmony remote. Instead of turning the lights off, its dimmed to itās lowest setting. Press the increase brightness button a few times after you turn the lights on for a work around.
Personally, I think it would be nice if any of these updates would fix the frequent and constantly changing list of my devices that are āunavailableā according to ST app however can be still turned off or on when forcing the app to do so - automation recipes donāt work however reliable when these devices are unavailable.
Very bad for me in the past few weeks. I have resisted posting about it or contacting Support as it wonāt achieve anything (typically my system is pretty stable so I donāt want to be told I have mesh problems). Very frustrated lately.
Thanks for the info, Hope this is not out of place, if so let me know were to post, But I really need a local zwave device for color and white bulbs (RGBW Light). There is one for ZigBee but I do not have them. I have a lot of zwave and need basic local execution when Internet goes missing during the huracane season.
It doesnāt make the issue less frustrating but device health is separate from Hub firmware. I also donāt want to inundate customer support but these reports are tracked. Letting support know which device was incorrectly marked āofflineā or āunavailableā and when is helpful.
I know Brad and I appreciate you taking the time to reply but itās exhausting to be honest. The list of devices with issues seems to rotate and usually the first response from Support is not particularly helpful and this takes time to reply with more of the same. My system was good for months and now itās having many failures. I just know it has to be ātweaksā happening on the back end yet Support usually wants to take me though endless troubleshooting steps that I have already done.
Again, thanks for replying. My whining here is not really achieving anything. Just needed to vent. At some point my issues will probably resolve themselves and no one will know why.
Iām also a tad off topic but I was replying to someone with the same issues. I do agree however that hub firmware is not usually the problem in these cases.
100% mirror these sentiments. My system has been having failures on a daily basis with upto 75% of devices disconnecting or not reporting properly on single occasions. It is indeed painful having threads with support go on for weeks with no notable improvement.
Is anyone else getting a stuttering/flashing affect from commands routed via Alexa and Google? I come home and request lights, and they get into this Flashing state (Like the there are two messages in the queue, but neither are being acknowledged) until I cold reboot the ST Hub.
Ditto on the Harmony remote issue. I was dreading the last firmware update, because everything in my system was working fine up until that point. All I have in my ST system is a Harmony remote, some GE smart switches & dimmers and some ecobee thermostats.
